Question about Kenmore 24032\24036 Top Load Washer
My 20712 washer will fill-up, and it makes the sounds like it is washing, but it is actually not moving. It'll go through all of the cycles beginning to end, but not actually move the articles of clothing at all.
  • 5,911 Answers
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 18, 2009
The washer knob does not make contact, needs to hold manually
Hello sunbill - Sounds like the switch behind that knob is beginning to fail. Consult a professional to move forward accurately and properly replace the switch.
Feb 14, 2013 | Frigidaire FEX831CS Top Load Stacked...
MY KENMORE WASHER , MODEL # 20712 991 70 SERIES FILLS WITH WATER AND NEVER GOES IN THE AGITATE MODE , IT JUST CONTINUES TO FILL(it would run over if allowed), WHEN YOU MANUALLY MOVE THE TIMER TO THE SPIN...
The water level sensor hose may have come off. This would require some dis-assembly to repair. Get the correct model number please to get a diagram.
Aug 07, 2011 | Kenmore Washing Machines
Bowl won't turn or spin. belt is fine but motor doesn't turn. the washing machine begins it's cycle fills with water but once it begins it's washing cycle the dial rotates to safety. The machine will also...
It sounds like you will need a new motor. You pump seems to work and that leads to the motor because it does not spin or move. Motor should be easy to replace good luck
Jan 08, 2011 | Asko W6021 Front Load Washer
Kenmore washer 20712 series 70 will fill but nothing else
Check at the back side of the motor to see if it turns freely. If it does, your motor is bad. If not your gearcase is frozen (bad). Hope this helps!
Feb 05, 2009 | Kenmore 24032\24036 Top Load Washer
Clicking Sound / Kenmore Elite Catalyst
sounds like ur coupler is bad easy fix 4 dollar part
Dec 26, 2008 | Kenmore 22422 Top Load Washer
Washer fills, drains, & final spin
Make sure the tub us actually moving. Sounds like the belt may have come off. That is what has happened to me.
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Kenmore Washer won't Agitate
gearbox internal fault, major repair, not really a do it yourself job.
Dec 25, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
153 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
