Computers & Internet Logo
A
Anonymous Posted on Sep 25, 2016
Automatic fail to fix it
Windows fall to open why
Is there a operation manual for Miller and falls ATS
This manual is all I could find. Instructions and Parts List for Setting Up and Operating Millers Falls Langdon Acme Mitre Box, Langdon Mitre Box : Form No. M709 : Millers Falls Co. : Free Download, Borrow, and Streaming : Internet Archive
I also found a few results on the web for "miller and falls generator automatic transfer switch". One of the results is a 240V Automatic Transfer Switch by Millers Falls that can be used with GSD7500 & GSD9000 Series Diesel Generators . This switch can be wired directly to the house or workshop mains power fuse box. In Automatic mode, the switch will automatically start the generator if mains power fails for whatever reason. Once the generator is up to full speed and generating voltage at 50Hz, the switch will feed the power into the required load point. When mains power is restored, the ATS will transfer load from the generator back to mains power then shut down the generator. This same function can also be performed in manual mode if required. The wiring of the ATS must only be performed by a licensed electrician. The solenoid operating mechanism of the ATS ensures a high-speed transfer of loads between alternate sources of power, regardless of current draw. These ATS transfer boxes are available in 3 models to suit Millers Falls GSD7500 & GSD9000 (silenced & open frame) diesel generators, GSD13000 diesel generators (silenced & open frame), GSC12000i-Y & GST11000A petrol generators
1helpful
I bought a used laptop with Windows 7 and came with office 2013. The auto update downloads the updates and shows the prompt"installation failed" , 10 or more times. Can this be fixed?
This worked for me, hopefully for you also.
*Fix Windows Update*
Control Panel
Administrative Tools
Services
Windows Update - Automatic
Windows Module - Automatic
If it doesn't download UNLOCKER http://filehippo.com/download_unlocker/ then delete the folder.
Then download FREE CCLEANER https://www.piriform.com/ccleaner/download run registry and delete all problems also run CLEANER and delete everything no matter how many problems it shows.
1helpful
3answers
How do i fix: "Failed to get address for D3DPERF
YOu need to update your DirectX. If still the problem exists then use a system utility software to repair your windows corrupt files, registry files and fix different operating system errors. I would recommend you to use system utility software RegInOut. Hope it works for you.
1helpful
The turntable does not move around when the microwave is on
ths is probably a failed motor they can go open circuit i have had a few where the fixing screws underneath that hold the motor fall out severing the drive spigot ,check if the spigot turns under the glass turntable if hard to turn will be motor failed cheap easy fix.
2helpful
2answers
What is an ArcCon ac application error0xc00000006?
What you describe falls under the general category of svchost.exe issues. Svchost.exe is used by your computer to access the registry and check the services to load during system startup.
arccon.ac is an ArcSoft Connect Notifier. There are two possibilities why its happening:
  1. Microsoft releases regular security updates that are installed automatically on your computer by the Automatic Updates feature, which is enabled by default on your computer. The Svchost.exe Application error usually appears due to a problem with a recent update.
Closing the error message might freeze your computer. To fix this error, perform the following tasks.
  1. Open Control Panel, select Performance and Maintenance, and then select Services.
  2. In the System Properties dialog box, open the Automatic Updates tab.
  3. Next, select the Turn Off Automatic Updates option.
  4. Select Apply and then OK to accept your changes and exit the System Properties dialog box.
  5. Restart your PC.
  6. Ensure that you are connected to the Internet and then select the Windows Update command from Start > All Programs to manually update Windows.
  7. After the update is complete, enable the automatic updates again from System Properties > Automatic Updates.
This should rectify your application error. However, if the error keeps reappearing, then you might turn off automatic updates permanently and manually perform Windows updates at regular intervals.
Errors Caused By Virus Infection
Let's hope that this isn't the case. Lengthy procedure but if you are still having trouble, we'll cross that bridge when we get to it.
2helpful
2answers
Rear window keeps dropping on a 2001 Olsmobile Aurora
The motor may be faulty or the track may have came off the motor gear. You will have to remove the screws and pry off the door panel to gain access to window, frame, and motor
1helpful
Door falls open
Without knowing the make and model of the dishwasher, it is hard to provide specifics. It is very rare for the hinge/spring to be repairable.
Generally, the hinge and spring assembly needs to be replaced as a single assembly. If you replace one, know that the other may fail soon, so consider replacing both.
Good Luck
May 05, 2009 • Dishwashers
Window Update Problem
Follow the steps below to solve this annoying problem when the Windows XP updates will download but won't install.
Make sure Windows installer 3.1 is installed correctly
Click on the following link to visit the Microsoft Download Center and download Windows installer 3.1
Download Windows Installer 3.1
Reboot the computer and try to download Windows Updates, if they still fail to install, continue with the next step.
Stop the Automatic Update Service
Click on Start, Run
Type the following command and press Enter
services.msc
Right-click on the Automatic Updates option in the Name column and click Stop
Close the Services window
Show Hidden Files and Folders
Open My Computer
Click on Tools, Folder Options
Click on the View tab
Under the Hidden Files and Folders section, select "Show Hidden Files and Folders"
Click Ok
Delete the Previously Downloaded Windows Updates
Open My Computer
Double-click on Drive C (or whatever drive Windows is installed on)
Double-click on the Windows folder
Double-click on the SoftwareDistribution folder
Double-click on the Download folder
Click on Edit on the menu bar
Click on Select All
Click on File on the menu bar
Click on Delete and delete everything in the download folder
Return to the SoftwareDistribution folder by clicking on the green up arrow on the toolbar
Double-click on the EventCache folder
Click on Select All
Click on Delect and delete everything in the eventcache folder
Restart the Automatic Updates Service
Click on Start, Run
services.msc
Double-click on the Automatic Updates option in the Name column
Click on the Start button under Service Status to restart the service
Select Automatic under Startup Type to start the service each time Windows starts
Click Ok
Close the Services Window
Download the Latest Version of Windows Update Agent
Click on the following link to download the latest version of the Windows Update Agent and save it to your desktop.
Automatic windows updates
r u wnt to stop your automatic update...........go to control panel then setup windows firewall or security center open left side change the way security center alerts me . all ok mark disable ..then apply ok
Grand Canyon Tech
Grand Canyon Tech
