Question about Garden
I purchased a vigoro electronic water timer from home depot and the wireless connection never seems to work. i've traded it in 3 times but never get one that works. the wireless symbol just blinks, indicating low battery or bad wireless connection, no matter what i do. please help
4 Suggested Answers
  • 864 Answers
SOURCE: water won't stop after removing a electronic water timerfrom hose
Check inside the faucet to see if the black washer there is worn, broken, or missing. Turn the water off inside the house, unscrew the nut below the faucet handle, and turn the handle in the ON direction to remove the stem. The washer is screwed into the stem at the bottom. Replacement washers are available at hardware stores, Home Depot, etc.
Posted on Jul 25, 2009
  • 3 Answers
SOURCE: Water is trickling out
No. Check to make sure the battery is good. If so, and you just purchased the timer, take it back.
Posted on Jul 02, 2010
SOURCE: my vigoro water timer i bought at home depot
I have a Vigoro 271-687 in which has worked well except when i change the batteries it wont reset and will not work do you have any solutions to this problem i really like this product just dont understand the prob
Posted on Aug 01, 2010
Pump is plugged into a hot line and will not run. It ran just over 3 months and quit totally.
Hello Mr Johnson.
I will help.
I am timer expert at fixya. Fixya answers question. We are not home depot or warranty carrier for grunfos.
Here are some ideas:
1) Buy another pump at home depot and return defect in new package
2) Talk to manager at Home Depot.
3) Check if outlet has power. Plug recirc pump into different outlet.
4) Check if override lever is set to OFF, because pump will not run when lever is in OFF position: Here is photo I took showing positions for lever:
http://waterheatertimer.org/Water-heater-recirculation-system.html#lever
5) These devices are prone to surge event. Nearby lightning strike can burn out any electrical device by energizing wires. The surge can follow any path seemingly random trying to find path down to ground.
Add a comment and say what happens.
Gene Haynes
Jun 04, 2013 | Laing Thermotech Autocirc Undersink...
I need instructions to the Vigoro- Duo Deluxe water timer 9 volt battery operated # on back is 0708..# on fromt top left is 225-379 Purchased at Home Depot I has5 to 6 cycles that can be programmed. I...
The vigoro duo delux might be same as Melnor 3100
Open following links:
http://www.melnor.com/instructions.php
http://www.melnor.com/instructions/3100_InstructionSheet.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Hardware & Accessories
We have a Vigoro Two Zone Water Timer. The timer started beeping and flashing that the batteries are low. We put new batteries in and it is still beeping and flashing low battery. What do we do now?
The timer is no good.
1) Clean battery terminals and make sure battery polarity is correct.
2) If you bought timer at Home Depot, call:
Internet Customer Service Center at 1-800-435-4654
3) If you live near Home Depot, then buy new timer and return defect timer in new package.
4) Here's what Home Depot customers say about this timer: the product will fail after 4 months, only worked one season, failed right out of box, new batteries did not restore functionality, etc. Only two good reviews.
Take a moment and vote on fixya answer:
Aug 26, 2011 | Hardware & Accessories
I have 2 Vigoro 196-036 watering timers. Why does water come out of the three holes near the battery compartment on one of them?
It comes out of the holes because the water goes in the holes. That might sound dumb but Vigoro designed these only to be in dry conditions, such as attached to the water line. I used them for sprinklers, but the water poured into the timer so bad it shorted it out in a week. I did find a vigoro timer with no holes and a sealed unit, and they work great. But I can't find them anymore.
Aug 25, 2010 | Hardware & Accessories
Water won't stop after removing a electronic water timerfrom hose
turn off water ar meter
remove valve or guts fron tap on wall and replace ruber washer
option 2 go to wallmart and buy a mini ball valve screw it on wall facet and turn it off voila it now turns off 3.99 and your grass is no longer a swamp
Jul 25, 2009 | Garden
My vigoro water timer i bought at home depot will not stay on manual off/om or on its program. I have installed the new 9 volt battery correctly since i can program ok but it shuts off in a short time...
Jul 01, 2009 | Garden
Jun 24, 2009 | Garden
Vigoro water timer problems
I also had this problem and found that the water pressure was too high. I turned the water spicket down one a a half turns (yours may vary) and now it's working fine.
May 05, 2009 | Garden
Garden Logo
374 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
