Question about Hitachi 15 LCD Monitor
Screen touched too hard,
A square exceeding the touched area no longer works, is this repairable?
  • 339 Answers
Unfortunately, no. The crystals have been broken.
Posted on Jul 18, 2009
The touch screen has ssstopped working
to look at the tiny areas that make touch screen happen was a neat part of my last career but my 24 years of copiers and touch screen repair and trying to jury rig for customer cost just didn't work. once these guys go there is very little you can do there is an expensive board to feed the touch screen and if its not on it's the other sorry I always get extended service JUST for that reason very hard to "fix"
Sep 25, 2014 | Tablets & eReaders
No ozone smell can it be repaired or do i need to buy another unit
You can try a couple of simple fix-its before deciding what to do.
The plates (4" white ceramic squares with screen glued to center of each side) must be clean and inserted correctly.
1) Soak the plates in equal parts plain ammonia/water for 5 minutes. Scrub gently with a toothbrush or small veggie brush. Rinse well. Blow dry or air dry. DO NOT use a towel or paper to dry it off. Avoid touching the screen with your fingers. Clean the metal fingers with a cotton swab and alcohol.
2) Insert the plates firmly, making sure they go in on the tracks, and that the contact fingers rest firmly on the screen part.
If you still detect no ozone, it's probably because the transformer is no longer working. Vollara (formerly EcoQuest/Alpine) no longer repairs or sells the Flair. You may be able to find someone (former dealer perhaps) who has parts and repair skills, or else you'll need to find another machine.
Jan 10, 2011 | Ecoquest Flair Air Purifier
Just received a used ds lite from ebay. when I type on the screen it enters the letter next to the one I touched. Is this a serious problem? Never used a DS before; will this have an impact on game...
Sounds like you should try recaliberating the touch screen. Calibration must be done with a stylus. Please note: Using a unlicsensed screen protector can lower the sensitivity of the screen, making calibration difficult. If the problem you are encountering started happening after installing a screen protector, this may be the cause of the problem. Remove all games from the Nintendo DS. Turn the system on by pressing the POWER button. Press the A Button when the "Touch the Touch Screen to continue" message appears. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button. should look like this :
icon_settings.gif Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button. should look like this:
    icon_calibrate.gif Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves. You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings. hope this helps
Dec 02, 2010 | Nintendo DS Lite White Console
Hp 2035 Screen touched too hard,
This is not repaireable but the screen can be replaced for under $100 bucks and you can get them off of ebay.
thanks
Jul 18, 2009 | Hitachi 15 LCD Monitor
My Htc Touch pro screen, looks like it has a large wet spot in the middle, i know for a fact it hasn't been near water, my screen is totally visable but not able to use by touching the screen, what could...
I suggest taking it to your compaany store but before you go to the store and have them tell u the phone is water damaged, you can save yourself the trip by looking for yourself. There should be a little square located in the back of you phone right below the battery and a little square locatedd on the batery where it connects to the phone. If the phone has water damage then the littl e squares should be red if they dont have water damage, the squares should be white with a plaid kind of design.
Jun 17, 2009 | HTC Touch Pro Smartphone
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
Nintendo ds lite
First try to recalibrate the screen (start up the DS, and do the following--text from nintendo.com):
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
  5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
  6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
    • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
    • Ifthe touch screen is not responding properly, hold the Nintendo DS at anangle so that you can see where the edges of the Touch Screen meet thehousing of the system. Look around the entire edge of the Touch Screenfor any foreign material (such as crumbs, etc.) that may be wedged inbetween the Touch Screen and the housing of the DS. Foreign material inthis area can cause the Touch Screen to work incorrectly.
If the screen still does not work, you need to buy a new touchscreen. Many vendors sell these, here's an example:
http://store.richspsxparts.com/nidslito.html
You will need a good tri-wing screwdriver to do this repair (don't buy a cheap knockoff--they will strip your screws). Try one like this: http://www.play-asia.com/paOS-13-71-1e-49-en-15-tri_wing-70-1fe.html
Then follow the step by step tutorial at:
http://www.instructables.com/id/Repairing-a-Nintendo-DS-Lite/
Dec 07, 2008 | Nintendo DS Lite Console
Left side of the screen not responding
  • Be sure that you're using only the bottom screen of the Nintendo DS Lite with the stylus. The upper screen is not a touch screen.
  • Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS Lite
  • If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen.
      • If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, clean the screen.
      • If the above steps did not help, there is a problem with the system and it will need to be repaired.
    7. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner.
    8. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
    Jul 14, 2008 | Nintendo DS Lite Console
    UNABLE TO CALIBRATE TOUCH SCREEN
    The only possible fix is to try to clean the edges of the screen in case any particles are trapped between the screen and the case, this can confuse the touch screen.
    Do this with a soft toothbrush, it will not damage the screen.
    If that doesnt work then in all likelihood the screen is broken, it can be replaced but this is not trivial. There are guides on the internet on how do do this.
    Dec 30, 2007 | Nintendo DS Console
    Computers & Internet Logo
    Top Hitachi Computers & Internet Experts
    Fotis Papastamatiou
    steve morris
    steve morris
    Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
