Question about HP Pavilion dv6208nr Notebook
HP Pavillion dv9000 will not boot up in normal mode, only safe.
So I come downstairs to my computer a couple weeks ago and try to boot it up. After putting my password in, it goes black and the cursor stays at the middle of the screen. I can move the cursor around but nothing comes up. I can open it in the Safe Mode(s) and can connect to the internet but my sound card, video card, usb, etc... doesn't work. My original course of action was to put everything irreplaceable on an external and reload my OS but...this can not happen without the USB working in safe mode... Any ideas?
  • thespreading Jul 18, 2009
    Is this possible by pressing F11 while starting up? I'm not sure where my discs are. I moved recently and haven't seen them around.
  • HP Master
  • 4,338 Answers
Have you tried an XP repair?
Then you can save your data .
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jul 18, 2009
    President:
  • 2,600 Answers
This happened to me with my compaq F700...after an automatic update the screen was changed to a resolution the monitor could not handle...thus the black screen...but if you booted in safe mode, you would have a screen because safe mode uses a lower resolution. While in safe mode, try changing your registry setting to allow for a lower resolution on your main start up and see if that clears the problems.
Posted on Aug 27, 2009
HP Pavillion dv9000. Intermittent stops. Cannot restart, but will do so after many hours. Screen turns blue with band of torn blue that looks like shutters. System carries out repair check - once worked...
Try booting your computer in safe mode... when your machine starts press F8 and go to Windows. Run for a couple of hours and see if this problem happens.
If you have system restore running, restore back to a point when you didnt have the problem
May 17, 2010 | HP Pavilion dv9000z Notebook
Pavillion dv9000 screen is gray, with external monitor connected,laptop will only start in safe mode using vista ultimate
Your display drivers could be corrupt.
Boot the machine into safe mode. Right click on Computer and select manage from the sub menu.
When the window pops up select Device Manager.
A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
Restart the computer and let it boot in normal mode.
If it boots in normal mode let it detect the Display and install the drivers for it.
I would be a good idea to update the display drivers via the HP support website.
Regards.
Oct 02, 2009 | HP Pavilion dv9000z Notebook
I cant seem to log on
try starting in safe mode. hold down f8 when you turn on your computer until you get a menu with the option to boot in safe mode. once you successfully log on in safe mode, restart your computer and the problem should be cleared. if not, we can explore further options.
Aug 14, 2009 | HP Pavilion dv9000z Notebook
HP Pavillion dv9000 screen disply problem
Try starting up in Safe mode by pressing F8 as soon as you see the HP logo on the screen at startup, then choose safe mode.
If there are colors within safe mode, try going to Start-->Right click on My Computer and go to Manage.
From there go to device manager on the left side and on the right side click the plus next to Display adapters
Under there right click and uninstall all display adapters, then reboot
Windows should reinstall all drivers for the display and hopefully will correct the issue
Jul 14, 2009 | HP Pavilion dv9000z Notebook
My HP Pavillion slimline won't get out of "start up repair"
Re-boot, keep on tapping F8, enter in, choose
"last known good" there, leave to re-boot,
Or
re-boot, F8 again, safe mode this time,
System restore then once booted into safe mode.
restart it.
Regards.
Apr 07, 2009 | HP Compaq Presario V2000 Notebook
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
HP Pavillion DV9000 ''Checkered Screen''
Yes it is a hardware problem not a software one perhaps replacing the monitor Im afraid nothing else will suffice...
Nov 11, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000 Problem
I understand that your Notebook is not booting into windows.
To isolate the issue please try to boot the Notebook in Safemode.
Restart the Notebook and keep pressing F8 key and select Safe mode to boot.
Please try to perform the following steps also
= Power Drain =
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
If your Notebook is booting into Safemode. Then try to restore the Notebook to factory settings. Before restoring the Notebook backup your data.
I hope this will work.
Thanks
Aug 12, 2008 | HP Pavilion dv9000z Notebook
Hp pavillion dv9000
boot in to safe mode and copy all your data from mydoc to other location.
press F8 after you power on your laptop go to safe mode...
Jul 19, 2008 | Acer TravelMate 2480 Notebook
Hp pavillion trying to boot from dos mode
This is a common HP laptop problem.
Please try these steps, if they dont work you will have to do a restore.
Please let me know how you make out.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372724&cc=us&lc=en&dlc=en&product=1137817&dlc=en&lang=en
Dec 08, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion dv6208nr Notebook Logo
838 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
