Question about GE Kitchen Ranges
GE Profile glass top stove. Large burner, only inside burner heats.
    Problem Solver:
  • 13 Answers
Had same problem with mine it was a bad burner a new one was 122.51 with tax. i tried the swich first and wasnt the problem. if you pull the burner out take a picture of the wires so you know where they go (theres 5) when you drop the burner you can see where the element is burnt. if the switch is the problem contact me aman2222000 @yahoo.com two 1/4 inch screws hold the top down if you open the oven you will see them and a phillips head screw driver takes the burner out. michael
Posted on Aug 22, 2009
I have a glass 4 gas burner stove top and cracked the glass, can I replace it? Its a GE Profile with a stainless steel front lip
Yes the glass is replaceable, you will have to order a new one, and you could do so through an appliance parts store. They can even put it in for you.
Mar 22, 2011 | GE 30 in. Profile JGP932 Gas Cooktop
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Glass stove top has a piece that has peeled back
once they are broken they are broken you have to replace he whole top
Feb 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
Electric Glass GE Profile Cooktop Burner popping
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
Jan 30, 2009 | GE Profile JGP636 Gas Cooktop
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Replacing glass top on stove
its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
Jan 05, 2009 | GE Profile Spectra JBP90SFSS Electric...
Only one ring of the double ring element works
You have faulty regulator, or the element is faulty., not sure how you access the inside.
Hope this helps.
Dec 05, 2008 | GE Profile JTP18 Electric Single Oven
Ge true temp stove top burner wont stay on
dont know how old unit is or how familiar you arewiththe unit, but the burner will need to heat up and cycle off/on. no matter how high or low you set the setting it will heat to a specific temp and cycle off, if hte burner remained RED all the time the glass would crak( so dont go by appearnce of burner, the glass should dictate the temp
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Glass Top Stove
Thak you, I decided to call a Service Tech from Sears who came and fixed it. Thanks
Sep 24, 2008 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
304 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
