Question about Remington Shotgun Mount 12Ga Lh, B Square 16801, 870, 1100, 1187 12ga In Catagory: Optics, Rings, Bases and Mounting Systems, B Square Rings, Bases and Mounting Systems, B Square Shotgun Saddle Mounts
My 1187 stays locked back after the first shot will not feed next round any ideas
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 231 Answers
The remington 1187 is a very nice shotgun. i myself would remove the **** stock by removing the screws un the **** plate the using a 9/16 or 15mm socket and enough extention to reach the nut that holds it to the actual firearm. the remove the forearm . soak the bottom half of the gun by submurging the entire trigger ans magazine assembly in a buckett of kerosene or some other mild solvent like mineral spirits for 24 hrs. make sure to do this with the magazine open during 12 hours of this and 12 hours closed. pick up a few cans of brake clean spray from the local parts store and begin a complete flushing out of any loose materials. then be sure to relubricate with a 3in1 oil or an equivelent. this should free up the machanism that triggers the chamber as to wether or not the weapon is empty.
Posted on Jul 18, 2009
Necchi 4595 feed dogs keep dropping
Tighten the screw under the plate near the feed dog
Sep 20, 2013 | Necchi 4595 Mechanical Sewing Machine
My Remington 1187 super mag will not eject shells once it has been shot have to play with it to manually eject them
Are you using light loads? Is the gun dirty? Too light a target load may be the issue. Also if you've shot many rounds through it, theweapon may need to be disassembled and cleaned to include the gas ports.
Sep 09, 2013 | Computers & Internet
Denzel 10 of his first 15 shots in a basketball free-throw contest.his success rate stays about the same for his next 100 free throws.write and solve a proportion to answer each part.round to the nearest...
He sinks 10 of 15 shots. 10/15 = 2/3 = 0.66, or 66% success rate.
66% of next 100 throws = 66 sinkers.
66% of 80 throws = 0.66*80 = 52.8 sinkers. Round to 53 per instructions.
What team does he play for?
Feb 04, 2010 | SuperTutor Homeworkhelp.Com Super Tutor...
Feed latch on Remingtion 1187 is not catching slide
Yes, it can be fixed or replaced, check to see what it is that is worn, get it replaced, or welded. Go to gunparts.com for a schematic of your gun. You can buy parts from them or try ebean. Hope this helps.
Jan 10, 2010 | Remington Shotgun Mount 12Ga Lh, B Square...
MY remington 1100 would not cycle second shell and now it will not allow me to put a second shell in
the lock spring is probably dirty, take it to a gunsmith for an overhaul and that should solve it
Nov 08, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Canon XSI showing "busy" when taking multiple shots
It can be that your batteries are low and takes longer to charge the flash... It can also be that your memory card is a slow on. If the red processing light on the back of the camera is staying on a long time, it means the camera is having trouble feeding the picture to the card... You might try decreasing the picture quality a little...
Jun 12, 2009 | Canon EOS Rebel XSi Digital Camera
After each shot the nail gun jams
hi visit your supplier and ask for a overhaul kit once fitted your tool will be licke new
best of look ian
Mar 25, 2009 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
Bosch wfm3200 rubber gasket
You need to turn the seal back in on iteself at the front, then starting at the 12-o clock position, start feeding the spring round into the recess you will feel at the rear edge of the seal, it is a goove and that is where the spring fits.
As you progrees round with the spring you will find it harder and harder to get it to stay in the groove, this where you could do with some assistance.
You need to have some one hold the spring in place as you progreeively fit the spring.
You may find you will have to have more than attempt.
As a last resort, you can stretch the spring, which will make it easyier to fit., but do not stretch it too much, or it will not stay on.
Plz leave feed back for this solution.
Dec 11, 2008 | Bosch WFMC 3200 Front Load Washer
Sony Cyber-shot DSC-W55...
Dear Julie339
Battery of your camera has less charge storage/ got weak.
Replace with new battery and try it. Hope problem would be solved.
May 18, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Remington Shotgun Mount  12Ga Lh, B Square 16801,  870, 1100, 1187 12ga  In Catagory: Optics, Rings, Bases and Mounting Systems, B Square Rings, Bases and Mounting Systems, B Square Shotgun Saddle Mounts Logo
298 people viewed this question
Top Remington Cycling Experts
Vern Reece
Vern Reece
Level 1 Expert
Piyal Perera
Piyal Perera
raysaw
Are you a Remington Cycling Expert? Answer questions, earn points and help others
