Question about Maytag MDE2600 Electric Dryer
Checked voltage left side about 120 left sied 0 and across both 0
What do you think is wrong and what needs to be replaced
  • Maytag Master
  • 4,654 Answers
Your high limit may be out inside the dryer that prevents overheating. Most times the is caused by a blockage in the exhaust going out the pipe and outside your home. It can also be because the thermostat for the heat is broken and cauded the dryer continues to overheat. If that is the case they both will need replaced. Let me know if you would like my assistance, Thanks, Sea Breeze
Posted on Jul 18, 2009
  • John Tripp
    John Tripp Jul 18, 2009
    You can put the model number into the model and parts search feature and click find it. That will take you to 2 models similar to yours. Review the parts and I will assist you in finding the solution, Thanks, Sea Breeze
    SITE 1=> http://servicepartstec.blogspot.com/
    SITE 2=> http://appliancepartseast.blogspot.com/
    PART NUMBER AND MODEL SEARCH FEATURE
  • John Tripp
    You asked what is wrong. You have lost one leg of the 220 volts somewhere. That can be double checked at the plug in for dryer. I believe you circuit may have lost the other leg of 120 v inside. But is possible to loose half at the source.
Why the heck is my compressor turning on and off, and on and off, and on and off?!
Has the compressor unit been modified?
The compressor motor should be the kind of power it is rated for. If it is a 120 volt compressor motor, the power feed needs to be of 120 volts.
If it is a 240 volt compressor motor, the power feed needs to be 240 volts.
If the compressor says it is 120/240 volts, then that needs to be checked, the wiring diagram given for the voltage applied must be followed.
Wrong voltage to the motor will cause an overcurrent or overload on the motor and cause the motor protection device to short cycle the operation of the motor.
If the above is correct in the compressor wiring, check the pressure switch.
The pressure switch energizes and cuts power to the motor directly. Is the pressure switch contacts staying closed? Is the pressure switch reading the tank pressure? The pressure switch has springs keeping pressure for them to stay closed, in contact, and if the contacts are pitted or defective, intemitent contact may show as a result.
Personaly, I think you have the compressor connected to the wrong voltage.
Oct 05, 2015 | Air Tools & Compressors
How to get 220 from breaker box
You are measuring in the wrong place! If you have a double breaker in the circuit breaker box, measure the voltage at the dryer outlet. You should have 110, 110, 220 at the different terminals.
If that isn't the case, then replace the circuit breaker (assuming that you have the right input voltage into the house)
Jan 01, 2012 | Dryers
Ice maker does not work. The water dispenser works, but not the ice maker
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold. Confused yet? LOL
Nov 11, 2009 | Kenmore 50522 / 50524 Side by Side...
The icemaker will not dispence ice
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Nov 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice crusher stopped working awhile ago. Today it started working again but the water dispenser stopped working? Any ideas?
replace the water valve write up below Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Nov 10, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Will run but has no heat. replaced element,thermastat and fuse
okay, you need to check to see if you are getting full voltage, see your dryer will run on 120 but if it is not getting hot, then you are losing 120.
see from left side of outlet to middle you should get 120
from right side to middle you should get 120
total voltage is 220-240 volts in order for dryer to heat
Sep 09, 2009 | Kenmore Dryers
Electric model# 110/63022100 KENMORE ELITE dryer turns on yet no heat so clothes don't dry if it's a heating coil where do i locate it or how do i get to it to get it out?
The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The first thing you should check is your wall receptacle voltage to ensure you are getting between 220-240 VAC across the HOT leads (LEFT and RIGHT slots). If your input voltage is wrong, the heating circuits will not operate, but the drum still may turn. That's because the drive motor only requires 110-120 VAC, while the heating circuits require the full 220 service. If the voltage at the wall receptacle is good, check the again at the terminal block in the back of the dryer. This is where the power cord is installed. Check across the RED and BLACK terminals for the same 220-240 VAC. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord. If the voltage is bad at the terminal block and wall receptacle, check your circuit breakers. Some installations have two breakers controlling the dryer. If one trips, the dryer may run, but won't heat. If the voltage is good at the terminal block, your problem is internal to the dryer. This may save you the need to open the dryer if you have an external problem.
On your dryer, the heating element is located inside the dryer under the drum on the right hand side.
In most cases the Thermal Cut-Out (TCO) fails before the Heating Element. If the TCO is defective, it is strongly recommended that you replace the Hi-Limit Thermostat at the same time. These two components are commonly sold as a set and are located on the heater box on the left hand side. The TCO is located on the end opposite the heating element terminals, while the Hi-Limit Thermostat is located adjacent to the heating element leads. Failure to replace both components may result in premature failure of any components you replace.
Make sure you take all resistance readings with the components unplugged to isolate them and prevent parallel resistance paths. If you do determine your heating element to be defective and need to remove it, please post back and let me know. I hope this helps you.
Jul 08, 2009 | Dryers
Dryer works but no heat, have a multimeter but need to know how to use and what to test
no heat at all? open front to access heater box, set meter to ohms. (unplug dryer), test for continuity across element connections. (disco at least one wire at each part to ensure accurate results for each check. then reconnect when done) some ohms is good here. if OL on meter then its open/bad. check each thermostat on side. they should all be 0 ohms. post results.
At terminal block in rear check voltage while plugged in. set meter to volts AC. each outside terminal to center should show 120 V approx. then together 240v. if 120 only on one side or one side significantly less than 120 then check outlet. Missing one phase/leg of supply can cause motor to run but no heat.
May 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Intertherm heater
You should have 24vac at the 2 lowest terminals 1 on each side of the sequencer with a call for heat.( that is the control voltage,the terminals are usually double spade brass in color) If you have the control voltage after about 30-120 seconds the sequencer should close.The voltage reading across the sequencer should go from 230vac to 0 volts when the sequencer closes.If you have control voltage and 230vac on each side of the sequencer then the sequencer is bad.It is beast if replacing the sequencer replace by moving 1 wire at a time from the old to the new.And ALWAYS make sure power is truned off.
Dec 28, 2007 | Heating & Cooling
DRYER PLUG
Unit has been damaged in the move. you will need to call someone out.
Jul 25, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE2600 Electric Dryer Logo
63 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
