Question about Craftsman 25cc Gas Line Trimmer
Cant get the end off to restring it - Craftsman 25cc Gas Line Trimmer
My granddaughter took weight off her new pixar cars pole And Reeled The Line In. How Can I Open The reel To Refeed It
Cover Of Reel Should unscrew use tweezers to grab the end of the line so you can restring it.
Jul 08, 2017 | Fishing
How to string a talon garden hawk trimmer
https://www.youtube.com/watch?v=tXUrdUoS_PU
Mar 18, 2015 | Garden
Restring clothesline hills
This may assist
"I found that Hills don't sell new line kits direct anymore, so I got some poly core line from Mitre 10, 60m for $30.
Study how the original line was strung through the clips and how it was tied at each end, and you will find that you have to remove 4 plastic wedges which secure the line in the end caps, these things
http://www.breezedryer.com/index.php?p=product&id=792
The wedge is not shown. You just push it out upwards. Then cut away and pull out the old line from all the clips, these things
http://www.breezedryer.com/index.php?p=product&id=741
Then tie the line onto one end cap as it was before, and restring the whole hoist. To get the line into the clips, you can carefully lever a bit with a screwdriver.
Don't worry too much about tension yet, just leave the line a bit slack on each run. You will have to pass the coil of line over the top of the arms many times. Finally cut it off after the final run, leaving enough line hanging down to secure the arms in a bunch when the hoist is folded up.
Make the final knot as it was, and then, without skewing the arms sideways, remove any slack going around and outwards, and finally pull in and tighten the final knot at the outer end, and replace the 4 wedges.
The line will stretch, so you may need this final step once more.
Sep 06, 2014 | Hills Rotary 8 Clothesline, Ocean
The string broke. It is a yard machine lawn mower
Take pull string housing off. Looks like 3 or 4 screws. Should be able to restring from under side. Either buy new string or if old string is long enough, just tie knot on the end. Good luck
Feb 03, 2013 | Garden
How to restring a husqvarna 224L
To remove the head to restring, push in the bumper cap/side tabs on the strimmer head, the top should then just pull off exposing the inner spool.
Jul 24, 2012 | Husqvarna Weed Trimmer 224 L 4-stroke Line...
Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Jun 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
Maytag DE 412 won't heat. Looking for a fuse.
No fuse on that old of a model . Probably element bad or thermostat . You can get a restring kit a lot less expensive , but you would have to restring it yourself (not that hard though) or , you can buy the element already strung and all you have to do is transfer the thermostat and install . complete pt # Y303404 ...Restring element pt # Y313538
Jul 19, 2009 | Dryers
How do I restring my Ryobi weed wacker I do not know which end of the string to start with?
Start in the center ,snap the center in place. than put the ends out through the holes.
Jul 10, 2009 | Ryobi Garden
Craftsman 25cc Gas Line Trimmer Logo
80 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
