Question about Fujitsu P5010D (AWA061A90ED00422) PC Notebook
P5010D does not start when pressing On/Off button
Fujitsu Lifebook P5010D notebook does not start when pressing On/Off button. Battery icon appears momentarily after inserting battery, then disappears. No response to on/off button when connected to charger, either. Any ideas?
  • 201 Answers
First is the ac adapter
next is the ac jack , if the pin is loose , or you have to move the adapter to get it to work, it could be bad jack
Posted on Jul 19, 2009
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
I'm using fujitsu life s series s7211 and could not start up my laptop . the fan is running, the battery icon is showing, but no screen.
Try to unplug the power from the back of the notebook and take out the battery and any other accessories. While no battery and power, press the power button for 10 seconds to drain everything inside. Plug the power back, turn it on w/o the battery. If you have a POST screen then try to go Fujitsu website to see if there's a new firmware for the notebook. If no screen then you need to take it to a tech/repair shop.
Mar 19, 2011 | Fujitsu LifeBook S7211 Notebook
Fujitsu Lifebook does not boot up
Have you tried draining the static on your computer?
Turn off the computer
remove the battery and adapter
press and hold the power button for 1 minute
plugged back in the adapter and battery
turned on the computer
if not resolved:
tried using an external monitor and connect to your computer to check if you can have a video on the external, if yes it is possible an LCD issue
Also, you may try using a flashlight in your LCD and check if you can see any, if none?
I suspect possible LCD issue.
May 21, 2010 | Fujitsu LifeBook A6010 Notebook
I have a Fujitsu Lifebook LBS6120 notebook
Turn on as you did before and leave on for 10 minutes. Then, try turning OFF the computer by keeoing the POWER button pressed for 7 secons. If the computer goes off, then your screen is fried and the computer is actually booting up normally... you just can't see it ;)
Mar 17, 2010 | Fujitsu LifeBook E8010 Notebook
3 others indicators start blinking !
Dear friend,
Just follow the instruction.
1. After press power button for turn on press F8 key.
2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and enter.
Then just wait and watch what's is going. If the same problem then contact me again here in Fixya i will give you another way to solve the problem. Thanks.
Feb 03, 2010 | Fujitsu Siemens LifeBook S7020D Notebook
My Fujitsu LIFEBOOK N3430 Notebook does not boot up the screen is blank
Remove the battery for 5 minutes, press and hold the power button for 3 seconds, wait 5 more minutes, put battery back in and see if everything works now. It should. This usually works.
If it doesn't, you may have a faulty memory chip causing you the black screen.
You can try removing one at a time to see if it corrects the problem.
Lastly, the ribbon cable from screen to motherboard can become piched and non responsive.
Nov 25, 2009 | Fujitsu LifeBook N3410 Notebook
My lifebook s7010 won't startup. After put the on button the screen still remains black. The fujitsu logo will not appear on the screen.
Unplug the AC adapter from power cord, then remove the battery.Wait 30 min and put the battery back.Plug the AC in power cord and try again.If not start you need check AC adapter with voltmeter.If the AC working your computer need service.
Nov 10, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
Fujitsu lifebook P5010D screen goes white when lid is opened more than 75 degrees.
Hey,
Most likely the cord is cut, you would need to replace the cables between the lcd and the motherboard.
Sep 01, 2008 | Computers & Internet
Fujitsu P5010D (AWA061A90ED00422) PC Notebook Logo
85 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
