Question about Hayward Pool & Spa
Pump is on but water is not circulating - Hayward Pool & Spa
Air in line loosen nuts on heater or pump
Posted on Jul 26, 2009
Ice maker kitchen aid kuic18nnts won't pump water over chill plate. Replaced circulating pump still no water.
Does the circulating pump- pump water? Remove the hose that goes to the spreader bar and run the unit again, if it moves water as a new pump should check for blockages in that hose and spreader tube. Get back to me if this doesn't work please. Personal email address kidlmo@gmail.com...
Jul 21, 2014 | KitchenAid KUIS18NNT 18" Automatic Ice...
What would cause a circulator failure?
I am going to assume the circulator pump is on a hot water circulation loop. Turning the water back on could have stirred up the sediment that has collected in the bottom of the water heater. This could clog up and possibly ruin the impeller. Running for an extended period without circulating water can overheat and damage the pump also. It is a good idea to hook a hose to the water heater drain and flush out the sediment periodically. Hope this helps.
Jan 18, 2014 | Bell & Gossett 103252LF NBF-22 Circulator...
Because if you put the thermostat at 300m water does not circulate when the thermostat is new
So you changed the thermostat?
Water will not circulate while engine is cold. As it reaches normal temp it should open and circulate. If it is overheating when warmed up, and still not circulating, then either the thrmostat is bad or wrong type, or it was installed wrong and somthing is blocking it.
One other thing possible is the water pump is broken, but usually when pump is broke, it leaks, from the back of the pump.
You could check the belt is correctly driving the water pump.
Apr 10, 2011 | 1999 Chrysler 300M
Need to trouble shoot circulator pump. Aquastat has power but need to figure out what is preventing circulator pump from kicking on.
Here is a tip that I wrote about heating circulator pump problems.
It will give you the information you need to learn about your circulator pump problems and solutions for it.
Heating Circulating Water Pump Problems
heatman101
Dec 11, 2010 | Honeywell HE360A1027 Whole House...
The taco cartridge circulator #006-BC4 was working fine. Then there was a brief power outage, now it is hot to the touch, and circulates hot water to one part of the house, but not to the other 2/3's of...
heatman101
Nov 06, 2010 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
We have a taco timer aquastat that's pretty hot to the touch; and were not getting hot water to the house. Does it need replacing?
The pump has air in it and you need to purge out the air..
heatman101
Aug 20, 2010 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
Dishwasher does not circulate water
I had a similar issue and it was the Motor Circulation Pump. Part #239144 @ Marcone Appliance Parts Center (860) 548-0080
Feb 01, 2009 | Bosch SHU5315UC Dishwasher
Pool & Spa Logo
439 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
