Question about Dell Dimension 2400 PC Desktop
Dell dimension 2400 hit by lightning. the green
Dell dimension 2400 hit by lightning. the green light on the board still comes on, so I don't know if the power supply is bad. Could it be the power switch? It won't turn on.
    Master:
  • 469 Answers
The fault could be with the power supply or some motherboard component. Check for the DIAG lights labled ABCD or 1234 on the back of the tower. The staus of the lights will help more on finding the cause. Try disconencting the memory, any addon cards like video cards and modem cards and CD and hard drive cables and see if the lights change. 5 Sensible Ipad Accessories For Business And Workplace Use AmanStino
Posted on Dec 27, 2016
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dell Master
  • 1,001 Answers
  • Flexible cord,lighting cable perfect forevery house hold ,when you want to use your device in bed or other on soft place
  • Durable,with nylon braided,better to protect the cable.
Amazon com Charm sonic 2Pack 4 9Feet 1 5Meters Lightning Cable USB Charger...
    Scholar:
  • 110 Answers
Posted on Jul 28, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 81 Answers
It can be one of 2 things:
1. if the battery charge light is all that comes on then you motherborad is busted.
2. if the power light turns on without the screen showing anything then you will need to replace the screen, but first connect it to an ordinary PC monitory and see if it works from there before changing anything.
Posted on Jul 18, 2009
I have a Dell Dimension 2400 and it had been working fine until recently. When powering on, it goes to the Dell screen, then there is 2 beeps and won't boot up. I checked the lights in the back for...
I've had a look at the Dell website, at
http://support.dell.com/support/edocs/SYSTEMS/dim2400/en/sm_en/advtshoo.htm
Which basically tells you to do what you've already done.
All I can suggest is you check again, but both ends of the ide connections to mother board and HDD / Disk drives.
If its dusty in there, I'd remove clean and reseat the ram and any PCI cards as well.
Jun 28, 2010 | Dell Dimension 2400 PC Desktop
Need the unlock code for my dell dimension 2400
Dell Desktop have a CMOS Clear jumper (usually a green or white) located on the board. Some one them also have a "password clear" jumper as well.
That should return the unit to clear and default settings.
Apr 26, 2010 | Dell Dimension 2400 PC Desktop
Dimension 2400 won't start up a green light comes on on the start button but nothing else? This isn't the first time this has happened, in the past what I could do was simply shut the machine off (hold the...
Hi There, the1st and quickest thing to try would be checking if the power supply is faulty, very common problem, if this isnt the problem then more than likly the motherboard. Let me know how you get on or if i can be of any help.
Regards
Grant
Nov 02, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 that has had a power surge
Um, unless you are happy soldering VERY finely and under pressure then go for it, but to be honest, you can pick one up for £30-£50 that will have everything you need and more!
Oct 14, 2009 | Dell Dimension 2400 PC Desktop
My dell was hit by lightning and now i cant get it to boot up
hi there;
really,lightning has a great power voltages supply,thousand of volts was supplied in one strikes of lightning.this depend how much voltage was induces on your computer,mostly your avr and psu might be damage by checking if there is power determining the fans inside avr and psu if running maybe you have the power,and some led light are blinking ,some how to be sure you can use multi tester if you have knowledge on this.basic approach if you have black out screen and good power supply,pull out ide cable of hardisk and cd room from mother board,you can run pc w/o them to check your start windows if will open run your pc if still black screen,take another video card and memory card try to replace them and rn your pc,if windows open fine if not maybe you have damage the mother board from lightning.replacing defective devices can put back your windows open.best regards
Jul 24, 2009 | Dell Dimension 2400 PC Desktop
Computer won't power up
The power supply should have given way. Replace the PSU and check if it works.
Jun 24, 2009 | Dell Dimension 2400 PC Desktop
Computer hangs at the Dee Logo
Look at the description for the diagnostic lights on a Dell 2400 here under "A possible expansion card failure has occurred."
If you have recently installed any card (wireless, sound, etc.), then this would be my first suspect.
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Lightning
In a nutshell, yes and not only to a Dell but to most computer brands/models. In some instances, it's only the modem, router, LAN card that gets fried while some gets everything toasted.
Incidentally, even a near lightning strike is enough to cause big problems.
Kind regards.
Dec 12, 2007 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
265 people viewed this question
Alun Cox
