Question about Splendide 2000S Front Load Washer / Dryer
I broke the door handle. How do I open the door?
I went to the RV dealer and looked at a new unit to see how the door handle actuates. After I understood that, I was able to take a screwdriver and GENTLY duplicate the same action. I had some success for several months after gluing up the broken handle before it broke again. The second gluing attempt didn't hold at all so we'll be purchasing a new handle unit. From some of the reader's forums, it is indicated that this is a very common problem. Supposedly, they have reinforced this replacement part. Unfortunately, you can't just purchase the piece that's broken. You have to buy the whole assembly for $40-$50. Nice after market income for the manufacturer since it happens so often - expensive for us. I just hope the new one is sturdier.
Posted on Aug 21, 2009
The handle broke off the door completely, therefore I cannot open the door of my Hotpoint counter saver plus microwaive oven. What to do please?
Take it to a repair shop you will have to take teh back off the oven and gain access to the door lock mechanism from behind.
Sep 14, 2014 | Washing Machines
Why will driver doorl only open from inside the car?
The outside door handle broke ! you can only see what broke by taking the door panel off . It's plastic an they break ! $47.95 new 1Aauto . This video is just to show you what has to be done to get to it ! 2006 2011 Cadillac DTS Paint to Match Outside Door Handle Rear Driver Side How To Install Replace Outside Front Door Handle Cadillac DeVille 94 99...
Aug 23, 2014 | 2007 Cadillac DTS Sedan
Sping in Emco storm door latch broke
I found a video that may help you listed below.
Best Regards my friend!
Mar 04, 2014 | EMCO Door. 300 Series 32 in. Bronze...
Passenger door handle broke of the outside of Nissan pathfinder, now the door wont open from the inside or out. how can we get the door open?
Remove the door's inner (interior) panel and inspect the trailing edge of the inside of the door. You should be able to see the door linkage from both the inner door handle and (what's left) of the outer handle (try moving the inner handle to see how the linkage is routed. I suspect that when the outer handle broke, its linkage dropped onto the inner handle's linkage and jammed it. With a long screwdriver, try moving the inner handle linkage to release the door latch and then replace the outer handle and its linkage (a salvage yard may be the best source and a Mitchell body repair manual should show hoe the linkage is routed and attached. Good luck.
Oct 10, 2013 | Cars & Trucks
1996 Chevy Silverado inside and outside handles to open broke. How do i open it
Only way is to get a coat hanger and make a small hook on one end and try to slide it between the window and door panel and try to hook the door latch from inside the door.
Jan 26, 2013 | 1996 Chevrolet C/K 2500
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
Need a new door opening handle?? the handle broke
You should be able to order one from Splendide. In the meantime, try using a screw driver to manually push the door release button.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 22, 2010 | Splendide 2000S Front Load Washer / Dryer
Open a suburban door when both handles are broke
ok easy to fix. remove door panel. when u have the replacement parts. start with the outside handle, remove the bolts, undo the bar, remove the handle. same with the inside handles
Mar 14, 2010 | 1999 Chevrolet Suburban
Driverside door handle frame is broken and cannot open the door
check handle is ok or broke
check behind handle shaft if it is came out from- handle point
Mar 21, 2009 | 1991 Honda Accord
Splendide 2000S Front Load Washer / Dryer Logo
550 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
JP Services
JP Services
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
