Question about Electrical Supplies
How to replace shaft
Want to replace short shaft on trolling motor with long shaft. How do you disconnect shaft from bottom?
    Sniper:
  • 64 Answers
STOP THE MOTOR! OPEN IT AND TKAE OUT AND REPLACE NEW ONE!~
Posted on Nov 04, 2009
Motorguide trolling motor
The first thing to check,(After making SURE the electricity is disconnected to the trolling-motor) remove the propeller and see if the shear-pin (Usually made of brass) in in place and not sheared/broken.
If it is, your local marine shop should be able to provide a new one. I always carry spares. If the pin is OK, the windings may have an electrical fault that would require a factory-repair.
Sep 05, 2014 | MotorGuide Transom Mount Great White...
Bearings for trolling motor shaft?
try a dealer who sells this machine or go on line to the maker and open up the spares section.
Jun 22, 2013 | Boating
I am having raqising my trolling up from the water using the rope . I have to trip the latch with a screw driver to get it to release every time
It sounds to me like you have a bent eye shaft (the location where the rope is tied is bent). Before you go and buy one, make sure to check for rust in the areas where the trolling motor releases. If you have no rust chances are good that you'll need to order an eye shaft.
Jul 13, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
How to get wires out of the shaft?
carefully drill out
the screws the are not removable to remove the cover. you will have to take apart the motor housing marking the outside for orientation for reassembly. this is critical as it could run backwards if improperly reassembled. you will need a seal kit for the motor as well. the wires that go to the coil pack in the nosecone are not removable. call the 800 number on the upper part of the motor for minn kota to ask any questions and to order new screws and a seal kit and any other needed parts. make sure motor is not attached to the battery at any time you are working on it. good luck.
May 31, 2010 | Minn Kota Edge 40 Freshwater Bow Mount...
My trolling motor maxxum 74# thrust feels like i have broken something in the shaft. It is almost impossible to turn and everything in the head looks fine (cables,gears,etc.). What is in the shaft that...
Here's a schematic for your motor:
Maxxum 74 Bowmount
I suspect the the bearings and cups are damaged and binding the tubes. Have a look at key #'s95, 78, 58, 59, 78A, 79. as these are the actual brgs and cups.
Good luck on your repair!
Mike
Sep 23, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Trolling motor doens't work
I have a trolling motor and can't seem to get it to come on. I seen it work when I got the boat. But now it won't come on.
May 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
Mar 17, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Minn-kota 865 autopilot
Hello dtspins2. Your footswitch is stuck. Disconnect the DC. Remove the bottom of the foot control, check the wiring for insulation broken off and wires shorting out, and disconnect a wire(note color of wires) from switch, reconnect power to confirm motor don't run. Remove the switch and contact your local electrical supply store(may cost less) or marine store for replacement. Good Luck.
Sep 07, 2008 | Boating
Electrical Supplies Logo
132 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
