Question about Poulan WeedEater Hedge Trimmer 25cc Engine
Should there be two lines going into the fuel inside the tan k
  • 155 Answers
Yes one is the pick up line and should have a filter on it, The other is a return line which usually comes from the primer.
Posted on Jul 27, 2009
Fuel gage undependable
If your meaning it "floats" around, it probably needs a fuel level sensor. some were serviceable separate. Others had to be replaced with the entire fuel module.
Nov 04, 2013 | 2001 Chevy C1500 Truck Inside Door Handle...
Craftsman Gas Powered Blower Mode 358.794772: Fuel lines broken and need replacement. Have new parts from Sears. One fuel line goes to the carb and connects to the fuel filter inside the fuel tank The...
A special fuel filter must be on the end of the fuel lines going into the tank, the line should be long enough for the filter to move around by gravity to stay in the fuel as the tank empties.
Sep 13, 2013 | managemylife.com
Where does the ground wire go on electric fuel pump relay after it leaves relay 0n 1987 ford bronco2
The reset fuel pump on a 1987 Ford pickup truck is inside the cab, behind the passenger side kick panel. ---------------------------------------------------------------------------------
VChecker V500
Apr 02, 2013 | Ford Windstar Cars & Trucks
Toro str will not start, motor spins but will not fire
Ensure clean fuel. Always use Stabile in fuel. Follow fuel line from fuel tan to carb, ensure no leaks. Remove carb fuel bowl to check float operation. Have pliers to crimp line or use fuel shut off valve. Remove carb float bowl and clean. Float should hang down freely gas should flow. Push float up gas should cut off. Replace spark plug, ensure plug wire snaps on tight. Clean or replace air filter. Ensure oil is full, 30w oil. All mowers have low oil shutoff.
Sep 12, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Where is the fuel filter located on a 94
look under rear vechicle where fuel tank is, you will see fuel filter.let vechicle sit over night fuel will return to fuel tank there wont be much fuel pressure when you replace fuel filter gas wont spray all over the place go to dealership buy tan oring that go on fuel filter dont use black universal o rings gas will destroy it. lubricate new o ring with few drops clean engine when instaaling o ring on fuel filter fuel line.
Feb 10, 2012 | 1992 Chevrolet Corsica
Apparently not getting gas. How do you clean gas lines?
There is nothing to block in the hoses themselfs, there will be a fuel filter on the end of the hose inside the fuel tan, just hook the pipe out and replace the filter, if this does not cure it, the blockage will be in the carb itself, let us know if you need help to clean the carb out.
Feb 27, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw starts runs 5 seconds then turns off
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Does the primer bulb fill with fuel after several pumps? The carburetor may need to be cleaned internally if the above doesn't help. Check the condition of the lower diaphragm for flexibility and no cracks or holes when working on the carburetor. Inspect the insulator inside the spark plug--it should be a light tan color if running correctly, but may be black (too much fuel) or white (insufficient fuel). Macs seem to require judicious use of the choke until warmed up. Make sure the 'fast idle' is being set (don't 'blip' the throttle during warm up). Hope some of this helps!
Dec 29, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Original AC Condenser fan motor had three wires L1 L2 & Fan Capacitor The replacement Dayton motor has 4 wires, L1 L2 & 2 capacitor wires solid tan and tan with white tracer One goes to the F...
Yes, that can be confusing...hook the tan wire with the white strip onto the same line wire as the one going to the capacitor...usually the L2 wire....so then in reality you have the two tan wires hooked onto the common and the F terminals of the cap...
heatman101
Aug 15, 2010 | GE Heating & Cooling
Poulan WeedEater Hedge Trimmer 25cc Engine Logo
379 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
