Question about Samsung DVD-V4800 DVD Player / VCR Combo
I tried to load a dvd. It timed out and I cannot eject it. When I hit the eject button, I hear activity but then that times out also. Any help would be greatly appreciated.
  • 3,741 Answers
OFF the unit completely.remove the main power cord from the power outlet.then press the eject button and insert the power cord in the outlet.then turn the unit on.then check out.if not solved press the eject button 10 - 15 times in 5 second and check out. if still the problem.then take a two thin knife insert in both sides of the player from where the tray comes out.and tell some body to press the eject button.and slightly pull the tray out by the knife.many times the sides of the tray gets bit rashed but no problem it will not spoil the unit. do it carefully. Please do rate the solution. Thank you for using fixya.keep updated. thanks
Posted on Jul 18, 2009
My jvc 5 disc player wont play cd nor dvd.says tray errr. wont open to eject dics or play
It is possible that the loading belt needs to be replaced, or the timing gears are out of sink, either way it must be taken apart to find the problem, sometimes I find the gears ware out causing the unit to lock up. When you hit the eject button do you hear a motor running? that should be the sound of the loading mechanism trying to eject the tray.
Dec 23, 2010 | JVC FS-GD7 Shelf System
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Regards
Jul 25, 2009 | NexxTech DP3222 DVD Player
Eject botton does not respond
there is a tiny drive belt connecting a small motor to the loading tray.when they stretch,they run but do not open the door.if that is the case,putting your ear on the machine while hitting the eject button will enable you to hear the loading motor running inside.if you do not hear anything,it is a different problem
Jul 13, 2009 | Philips DVP5140/37 DVD Player
Samsung blu-ray player won't eject, tried turning off power strip and waiting 10minutes then trying again, still didn't work
I had a similar problem with my unit. every time i hit "eject" the screen would display "eject" for about a minute then display "loading" indefinitely. no mater how many times i powered on or off it just would not spit out my disc. However, I hit the "function" button on the player and cycled through radio, aux. etc. and that seemed to un-freeze it. I was able to eject my DVD while the player was set to radio. give it a try and hope for the best.
Jun 11, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
My Avic d3 won't eject
Try holding the menu and left arrow button at the same time you hit the (little) reset button. As the system reboots hit the eject button a few times. You may need to do this cycle more than once.
Nov 15, 2008 | Pioneer AVIC-D3 Car DVD Player
Dvd will not eject manually or with remote tried unplugging and restarting it didn't help
It probably wasn't the best solution but it worked. I tried to jimmy open and pull out the dvd tray. When that didn't work I tried pulling the dvd out with needle nose pliers, but it did not budge. Finally I hit the eject button one last time and it worked. I hit the eject button a couple of more times and it did work. I did ruin the dvd, and haven't had a chance to play another dvd to see if it is working properly.
Nov 10, 2008 | GoVideo Go Video DVD/VCR Combo
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Technical support needed can't get player to eject disc
Huncha,
I had the same problem today.  I got a screwdriver and opened the case from the back.  It was simple, just 3 black screws.  Then I looked in the unit and saw that there were 2 dvds loaded in the unit. Apparently, my daughter didn't realize a dvd was already in the loading tray when she loaded another dvd.  I gently removed the 2 disks by prying the black plastic holder open and sliding the disks out.  Then I put the cover back on and put the screws back in.  Works fine now.  I hope this helps you.  I don't think the unit has a manual eject button, but it sure was easy opening the case and looking in the unit myself.  Good luck.
Dec 27, 2007 | Samsung DVD-P241 DVD Player
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
Samsung DVD-V4800 DVD Player / VCR Combo Logo
50 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
