No display, no power light - Computers & Internet
    Sergeant:
  • 157 Answers
Try checking the Power connection on the system. If it is fine, try using another power cable and if it still a problem Try to reseat hdd, memory and DVD drive.
Hope this Help.
Cheers!!!!
Posted on Jul 18, 2009
BOUNCING CHARACTERS/DISPLAY
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 22, 2014 | AOC 19" LED Monitor e950Swn Black
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Aspire 5542g
When the following conditions, namely the need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Jul 26, 2013 | Computers & Internet
Power is on but after 2-4 seconds display turns off but power is still on where the power light is in blue.it's not in sleep mode where the power color is orange.it just goes back to normal at random...
Without looking at the monitor to confirm this, I suspect you have failing capacitors which power the HT circuit, simply, the power needed to light the display, is leaking to earth, capacitors have lost the ability to store the charge necessary to illuminate the screen, which is why it is working erratically.
You need to get this checked out by a TV technician.
Jul 23, 2011 | Acer Computers & Internet
Our computer (SAMSUNG type GH15LS,540N MODEL,COLOR DISPLAY UNIT) CAN NOT DISPLAYED WITH BRIGHTNESS.DO NOT SEE DISPLAY DUE TO LIGHT LACK IN MONITOR.BUT OTHERS ARE CLEAR.KINDLY GIVE A SOLUTION FOR POWER...
The light on display is produced by a lamp over or under the LCD (TFT) display, or by the heated CRT electrodes on CRT display. Your lamp or CRT may have gone damaged.
Jun 05, 2010 | Measuring Tools & Sensors
Power light is blinking but no display on SMT-170 MONITOR OR SECURITY SYSTEM. SYSTEM DUAL QUAD SOQ-080N
u have problem with Display from the Coputer not from the Moniter
try to run from baios mode
and re setupp your display
May 11, 2010 | Samsung SMT-170 PROFESSIONAL 17" TFT-LCD...
MY toshiba satellite 2430 CAN NOT POWER UP. BUT IT ALL THE LIGHT IS ON WHEN I SWITCH ON THE DC POWER SUPPLY SWITCH. WHAT IS THE PROBLEM? HELP.
remove the battery and remove the power adaptor ... press and hold the power button in the ON position and count to 20.
attach the AC adaptor only and press the power button ...this should fix the issue ... then re connect the battery.
if this does not work then add a external monitor .. if it lights up then hit the
Fn + F5 keys
Display modes
Fn + This hot key cycles through the power-on
display mode options.
The display mode options are:
Built-in display panel only, Built-in display panel and
external monitor simultaneously, External monitor only.
Fn + This hot key cycles through the power-on display options.
The display modes are:
❖ Built-in display panel only
❖ Built-in display panel and external
❖ External monitor only
video device simultaneously
❖ External video device only
Oct 07, 2009 | Toshiba Satellite 2430 Notebook
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Computers & Internet Logo
326 people viewed this question
David Payne
David Payne
