Webroot Spy Sweeper (spysweeper) for PC Logo
Posted on Jul 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I uninstalled Spy Sweeper because I can't afford a new yearly program. I now have the problem that pops up and says i need to go to a programs page to fix. I don't know what it is talking about and very annoying to have to program pop up every time I try to open or close the computer, please advise
Anonymous
Level 3:
  • Master 334 Answers
  • Posted on Jul 18, 2009
Anonymous
Master
Level 3:
Answers
334
Questions
5
Helped
136865
Points
1048
First get rid of spy sweeper. Go to
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-8022_4-10804572&ontId=8022_4&spi=b5c7fb43cc830a1a662de675889e835b&lop=link&ltype=dl_dlnow&pid=11080953&mfgId=6290020&merId=6290020&pguid=gFBMOgoPjAIAAFuCU6sAAAAw&destUrl=http%3A%2F%2Fdownload.cnet.com%2F3001-8022_4-10804572.html%3Fspi%3Db5c7fb43cc830a1a662de675889e835b%26part%3Ddl-10804572
save the file to your desk top. reboot in safe mode (hold down F8 as soon as it powers on) install the file, skip update, run a full scan and remove infections found. then go to www.comodo.com and install their free firewall and antivirus for your permanent security program. It is a full suite and it is free. If spy sweeper won't uninstall, try to do it in safe mode too. The system cleaner o the comodo website is very good as well and will probably speed your computer up, run the power clean feature after evrything else is done. Let me know if you need anything else.
seth
Difficulty uninstalling webroot off my computer
Right-click on the Webroot Spy Sweeper icon on your computer's taskbar. A menu for the program will appear. The taskbar is the bottom bar of your computer. The Webroot Spy Sweeper icon looks like a green bulls eye.Select "Exit" from the Webroot Spy Sweeper menu. Select "Yes" if asked if you wish to shut down the program.Click on the "Start" icon and select "Control Panel."Click on "Add / Remove Programs" if you are using Windows XP. Select "Programs and Features" if you are using Windows Vista or 7.Click on the "Webroot Spy Sweeper" program listing.Click on "Uninstall." A Webroot Spy Sweeper uninstall wizard will open.Select "Uninstall" in the wizard and hit "Next." Follow instructions on screen.Restart the computer if prompted.Click on "Start" and select "All Programs."Right-click on the "Webroot Spy Sweeper" folder and select "Delete."
I accidentally Uninstalled by software while trying to update to a newer version. How do I get it back?
Ascertain the type of program that has been uninstalled from computer to determine methods to reinstall. For example, discovering that spy sweeper program was uninstalled makes possible to attaining the same program or alternate. Spy sweeper program once acquired on disk becomes reinstall able or makes adjustment modification attainable with encounters experienced on computer. Ascertain that type of software to determine whether acquirable from retail markets either at physical store location or online internet purchase. In situation that least has the program available as replica requires purchase however similar programs perform like spy sweeper on computers. Visit a computer retail store to ascertain the resource that makes effective resourcefulness.
1helpful
How do i uninstall my old webroot spy sweeper?
go to control panel>add or remove programs or uninstall a program>then a window will popup then in the listing locate webroot spy sweeper and click uninstall,i hope this will work,thank you for using fixya!
CAN'T FIND UNINSTALL FILE FOR SPY SWEEPER. Is causing conflicts with Trend Micro
Have you looked in the Spy Sweeper folder, most probably C:\Program Files\Webroot\Spy Sweeper and looked for the uninstaller - unins000.exe
You could always search for this file through Start>Search, select all files and folders and type "unins000.exe". It should find the file, this is the uninstaller, just double click.
You could also start in Safe Mode (restart computer and hit F8 when computer first starts) and delete the webroot folder C:\Program Files\Webroot\ . Do NOT try to delete the Program Files folder...
Good luck! Let me know if you need further help. I will check back tomorrow.
Webroot spy sweeper window says program damage
have you tried uninstalling and reinstalling a program or yo ucan also try doing a system restore either of this will work
2answers
Installing a new antivirus program
if you know registry editor then go regedit find all webroot stuff and delete
How can i remove webroot spy sweeper with anti virus from my computer?
To uninstall Spy Sweeper :: let Microsoft Windows uninstall the software automatically.
1.clicking on the Start Button
2. Select Control Panel
3. Select Add and Remove Programs.
Occasionally this method will not work, and produce an error about not being able to uninstall the software. If this happens right click on the Spy Sweeper icon on the right hand side of the toolbar where the clock is located and select exit This will shut down the Spy Sweeper program. Next press ctrl + alt + delete which will open the Task Manager. Click on the Processes tab. Search for spysweeper.exe. If this process is running click on it then select end process. Repeat this step to search for and close the process WRSSSDK.exe. After this is done Spy Sweeper should be able to be removed by using Add/Remove Programs
1helpful
Uninstall
Hi Jeli
most effective way to uninstall Spy Sweeper is to go to Control Panel and then select Add and Remove Programs. In this case, you may try to follow the instructions below.
1.right click on the Spy Sweeper icon on the right hand side of the toolbar where the clock is located and select exit
2. press ctrl + alt + delete which will open the Task Manager.
3. Click on the Processes tab. Search for spysweeper.exe. If this process is running click on it then select end process.
Keep me posted.
Thanks.
Spy Sweeper won't sweep
I have seen this problem a couple times. The only fix that seems to work is uninstalling Spysweeper and then reinstall it again. If you go to start>Programs>webroot you will see an uninstaller. Run that, reboot the computer, then reinstall again from your install disc.
2helpful
2answers
Error message:could not locate a valid definitions file.Please go to the program options page and click "update definitions" to download a definitions file.
Use Norton-Cleensweep to uninstall.
You can download Norton System works.
Use torrent for Free download of NORTON SYSTEMWORKS. (www.btjunkie.com)
Top Webroot Computers & Internet Experts
Mike 'H'
Mike 'H'
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
