Question about Sirius HONSC1 Interface for Honda/Acura
Car cranks but wont start unless i step on the gas okay i have a gsr bottom with a b16 head vtech,car wont turn on the only way to turn it on is by steping on the gas but it stumbles and smoke if i stop pressing the gas it would die,i could press the gas to the end and it looks like if am not pressing it.i have 450cc injector and a walboro 255 fuel pump is good, i hear the ''clicks'' and the fuel pump.i cant read my codes cuz i have a p28 cipped ecu...is there a way i could read my codes with a chipped ecu???
Go ped wont start unless i put my finger over carb throat
sounds like a loss of vacume check the gasgets for cracks and seal them or buy new ones
Sep 16, 2014 | Go Ped GSR Sport Gas Powered City Scooter
Tip
How to install a subwoofer and amplifier
When installing any electrical components always remember to unhook the battery. First thing you want to do is run your ground cable from a volt meter to a body or frame nut or bolt near by in the trunk or hatch area a shorter thicker ground is best then connect the other end of your volt meter to your battery cable that will need to be run through the firewall and connect to the positive battery terminal. Also VERY important make sure you have installed a fuse on the wire in between the amp and the battery. after you have connected the battery cable and ground to your meter it will light up or give you the correct reading for your ground, if not run the ground somewhere else until you have found the right spot. pull out your stereo, for stereos that are made to be compatible with an amp there will be multiple rca jacks in the back of the stereo. For a sub woofer you want to hook the rca cable to the rear or sub labeled rca jacks. Then run your amplifier remote wire to the remote wire protruding from the back of your car stereo. After that you can run the ground and battery cable to the correct slots. Now connect your sub via rca and your done. making it fit correctly is up to you. If you do not have an amp with a subwoofer out then you can take the wires from your sub and bridge the connection to your amp and get enough power, take the positive wire to your sub and hook it up to the positive terminal of channel one on the amp then take the negative wire from your sub and hook it into the negative terminal on channel two and your done.
keywords: subwoofer, fuse, wiring, car audio, car , car audio install, speakers, dvd player, in dash, acura integra gsr del sol honda civic itr ls b16 hatch coupe jdmkey words: honda acura integra gsr itr jdm del sol coupe hatch ls si boosthonda, acura, civic, crx, si, hx, two door, integra, DA, EF, EG, EK, DC, DC2, DC4, hatchback, four door, GSR, LS, GS, RS, EX, DX, VX, engine, transmission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15,key words:VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, integra civic, b18, turbo spoon,JDM,EK9,da6,eg,civic,HB,honda,acura,turbo, acura Honda Civic Integra EG6 EK9 EK4 DB8 DC4 ITR CTR civic honda jdm integra ls gsr b16 b18 civic si crx k20 swap hatch coupe lx eg ek ef b20 accord prelude sedan trade sir type-r lsd b18c5 b18c1 turbo supercharger b-series integra da dc eg ek ex gs rs ls gsr lsr rs si sir sirg wanted prelude accord transmission eg ef ek em ep civic integra del sol s2000 s2k rsx accord gsr type r itr ctr vtec v tec honda acura blades ls mesh rota volk 4 lug 5 lug b16 b18 h22 h23 b20 k20 d16 d15 b series h series d series turbo all motor eg ek da ef crx dc2 dc5 dc em ej ap1 f20 prelude jdm edm ukdm doch b18a b18 b18c1 b18c5 rota rsx integra DA ef eg ek hx rims si rims gsr blades ls distributer distributor rota rotor aem injen akimoto parts works obx hatchback honda acura integra ls rs gs gsr type r civic dx cx ex hx lx si crx hf del sol oem jdm da da9 da6 db dc dc2 ef ef8 ef9 eg eg6 motor integra da dc eg ission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, suspension, break, brake, greddy, tanabe, cusco, zex, nos, turbo, drag, hks, aem,subwoofer powered subwoofer subwoofers svs subwoofer
home subwoofer car subwoofers best subwoofer subwoofer cable
subwoofer reviews car subwoofer klipsch subwoofer subwoofer wiring
home theater subwoofer yamaha subwoofer subwoofer amplifier
jbl subwoofer subwoofers for sale jackhammer subwoofer subwoofer boxes
hsu subwoofer sunfire subwoofer kicker subwoofers pioneer subwoofers
subwoofer car audio car audio subwoofers powered subwoofers
cheap subwoofers home subwoofers 15 subwoofer
subwoofer placement computer subwoofer active subwoofer
velodyne subwoofer mtx subwoofer kicker subwoofer subwoofer box
infinity subwoofer home audio subwoofers
car speakers and subwoofers
cheap subwoofer
home theater subwoofers
rel subwoofer
wireless subwoofer
jbl subwoofers
10 subwoofer
subwoofer speakers
8 subwoofer
bazooka subwoofer
subwoofer enclosures
custom subwoofer boxes
on Jan 28, 2011 | Honda Civic Cars & Trucks
Tip
Car audio installation... important
when installing a sub woofer and amplifier to your vehicle always make sure that you also install a wired fuse in between your battery and amplifier without this problems may occur...
cheap subwoofer
rel subwoofer
wireless subwoofer
jbl subwoofers
10 subwoofer
subwoofer speakers
8 subwoofer
bazooka subwoofer
on Jun 03, 2010 | Car Audio & Video
My goped sport engine shut off and wont start again, what I can do?
Try the steps on this website. http://goped.8m.com/racingpages/troubleshooting.html
May 30, 2014 | Go Ped GSR Sport Gas Powered City Scooter
1990 Lexus ls 400 giving me hard time to start
Have the cold start fuel inkector checked for flow.
Nov 12, 2013 | Lexus LS 400 Cars & Trucks
Car wont keep running unless foot is on gas pedal
Here's a video Andres Nazario suggested as a solution to your problem from YouTube:
Fixing A Car That Cranks But Doesn't Start Up
Apr 30, 2013 | Honda Accord Cars & Trucks
Car won't start without a jump but battery okay
wont crank or wont start.??
no car starts , if it cant crank. (unless push starter (M/T magic)
that is not a trans sensor its the PRN switch.
ill answer for, wont CRANK !
it wont crank even with a good battery (charged) or jump started.
1: bad start
2: bad wires to same.
so hot wire the starter small wire, the key start line is tiny.
cranks. , starter good, no crank starter bad or cables bad.
if it cranks hot wired, then the key line is dead.
easy, huh?
Feb 11, 2013 | Suzuki Forenza Cars & Trucks
My honda civic has no power at all i tried to jump
check ICM & ignition coil - one of them is bad.
Jul 09, 2009 | 1997 Honda Civic
What should i do? B16 or piston rings?
well its about what you want the single cams can rev high...the 2nd fastest world record is in a turbod d16 ...202mph for a single cam civic..the b16 has more dynamics in the high end of boosting... the b16 aftermarket is stronger but they **** on the low end of the rpm gauge..
the best motor is the b20 crv block its 500 bucks you can vtec it with a b16 head and run big loads of turbo and get to the 10 sec class of things...if you go to b series you will need to change the ecu to hondata and you should look for ls integra trannys...next the axles ...I reccomend B20 its a harder build but its worth it and youll spend 1000 less than an gsr or prelude motor...google the b20 dart motor with ITBS you will see!!!!!!!!
May 08, 2009 | 1992 Honda Civic
I just replaced cylinder head and now my car wont start up
Is timing correct?
First make sure you are getting spark.
Some questions you need to know are what year head is the LS. Did you use the LS Intake manifold and throttle body. Problem is if you didnt use a OBD1 LS and it is OBD2 or OBD0 The Throttle position sensor wont allow the engine to start. Same with the Distributor, because your crank angle position sensor is in your distributor and a OBD1 ECU can communicate withe OBD0 or OBD2
If it is all OBD1 Then I would do a compression and Cyl. Leak down test.
Nov 29, 2008 | 1994 Acura Integra
Sirius HONSC1  Interface for Honda/Acura Logo
500 people viewed this question
Top Sirius Car Audio & Video Experts
xxxxxx xxx
Are you a Sirius Car Audio and Video Expert? Answer questions, earn points and help others
