I have a samsung dvd-v4800. I stuck a video in and cannot eject it; it tries to load and times out. If I hit the eject button you can hear activity but it times out also. Any help would be greatly appreciated. Thank you. Ed
    President:
  • 2,187 Answers
This happened to me once with an LG player, somehow the mechanisms did not mesh with each other that it needed help at times. If your player is no longer in warranty, open the top cover, there should be screws on both sides. On the DVD side there should be a cover on top as well have this removed especially if you are having difficulties see seeing the parts. Observe the mechanisms as you press the eject. In your case it could be a stuck up motor, mechanisms that do not interlock or mesh or loose parts. It may need a little nudge to get the DVD to the next phase and eventually to eject.
Posted on Jul 18, 2009
DVD is stuck in player. It will not eject.
Make sure it is powered on. Press power-on button then try to eject. If not, then press the power-on button and try to eject. If neither works, return to the sore or website where you bought it and ask for replacement.
Dec 26, 2017 | Insignia NS-24LD120A13 24in 1080p LCD HDTV...
CD is stuck inside of a tv/dvd player
Try shutting the television off. With the unit turned off, hold the eject button and turn the unit back on. Continue holding the eject button for 30 seconds or until the DVD comes out.
If this doesn't work, try unplugging the TV for 5 minutes and attempting the above steps.
Hope this helps!
Dec 06, 2011 | Toshiba Televison & Video
Try to eject cd and it displays 'demostration
hit the little reset button next to the kenwood logo on the bottom of the screen. Or go here...http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/DDX8017.pdf
Oct 29, 2009 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Eject botton does not respond
there is a tiny drive belt connecting a small motor to the loading tray.when they stretch,they run but do not open the door.if that is the case,putting your ear on the machine while hitting the eject button will enable you to hear the loading motor running inside.if you do not hear anything,it is a different problem
Jul 13, 2009 | Philips DVP5140/37 DVD Player
Samsung blu-ray player won't eject, tried turning off power strip and waiting 10minutes then trying again, still didn't work
I had a similar problem with my unit. every time i hit "eject" the screen would display "eject" for about a minute then display "loading" indefinitely. no mater how many times i powered on or off it just would not spit out my disc. However, I hit the "function" button on the player and cycled through radio, aux. etc. and that seemed to un-freeze it. I was able to eject my DVD while the player was set to radio. give it a try and hope for the best.
Jun 11, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Dvd will not eject manually or with remote tried unplugging and restarting it didn't help
It probably wasn't the best solution but it worked. I tried to jimmy open and pull out the dvd tray. When that didn't work I tried pulling the dvd out with needle nose pliers, but it did not budge. Finally I hit the eject button one last time and it worked. I hit the eject button a couple of more times and it did work. I did ruin the dvd, and haven't had a chance to play another dvd to see if it is working properly.
Nov 10, 2008 | GoVideo Go Video DVD/VCR Combo
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
DVD Stuck inTV/DVD combo unit
Same here.  Had the TV for about 6 months and had a DVD get stuck for the second time.  Used the same method of unplugging and plugging back in.  Then hitting the Stop/Eject on the side and it came out.  When plugging it back in I could hear the DVD "engage".
Jun 06, 2008 | Westinghouse SK-32H590D Television
Technical support needed can't get player to eject disc
Huncha,
I had the same problem today.  I got a screwdriver and opened the case from the back.  It was simple, just 3 black screws.  Then I looked in the unit and saw that there were 2 dvds loaded in the unit. Apparently, my daughter didn't realize a dvd was already in the loading tray when she loaded another dvd.  I gently removed the 2 disks by prying the black plastic holder open and sliding the disks out.  Then I put the cover back on and put the screws back in.  Works fine now.  I hope this helps you.  I don't think the unit has a manual eject button, but it sure was easy opening the case and looking in the unit myself.  Good luck.
Dec 27, 2007 | Samsung DVD-P241 DVD Player
Dvd eject button does not respond
Had a similar problem after loading a suspect dvd (one I had buned myself) Could not do anything - stuck at loading.
Try this :
  1. Unplug and wait 10 seconds
  2. plug it back in and wait 1 minute. DO NOT PRESS ANY BUTTONS!
  3. With the machine still in the standby state, press eject on the REMOTE. It should eject without trying to read the disk.
Good luck. It worked for me.
Dec 03, 2007 | Samsung DVD-HR720 DVD Recorder
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
