I have a samsung dvd-v4800. I stuck a video in and cannot eject it; it tries to load and times out. If I hit the eject button you can hear activity but it times out also. Any help would be greatly appreciated. Thank you. Ed
  • 3,866 Answers
This disk may have been put in wrong you will need to manual eject this disk.
1. Unplug the unit
2. unscrew the screws for the top cover
3. lift the top cover off access the disk inside.
Gently push out the tray without stripping the motor gauges or teeth.
Following these steps will help you and fix the problem.
If you have any questions please hit the reply button. Otherwise accept and start fixing your issue with my solution.
Thanks for using Fixya.com
Posted on Jul 18, 2009
CD is stuck inside of a tv/dvd player
Try shutting the television off. With the unit turned off, hold the eject button and turn the unit back on. Continue holding the eject button for 30 seconds or until the DVD comes out.
If this doesn't work, try unplugging the TV for 5 minutes and attempting the above steps.
Hope this helps!
Dec 06, 2011 | Toshiba Televison & Video
My jvc 5 disc player wont play cd nor dvd.says tray errr. wont open to eject dics or play
It is possible that the loading belt needs to be replaced, or the timing gears are out of sink, either way it must be taken apart to find the problem, sometimes I find the gears ware out causing the unit to lock up. When you hit the eject button do you hear a motor running? that should be the sound of the loading mechanism trying to eject the tray.
Dec 23, 2010 | JVC FS-GD7 Shelf System
Try to eject cd and it displays 'demostration
hit the little reset button next to the kenwood logo on the bottom of the screen. Or go here...http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/DDX8017.pdf
Oct 29, 2009 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Eject botton does not respond
there is a tiny drive belt connecting a small motor to the loading tray.when they stretch,they run but do not open the door.if that is the case,putting your ear on the machine while hitting the eject button will enable you to hear the loading motor running inside.if you do not hear anything,it is a different problem
Jul 13, 2009 | Philips DVP5140/37 DVD Player
Samsung blu-ray player won't eject, tried turning off power strip and waiting 10minutes then trying again, still didn't work
I had a similar problem with my unit. every time i hit "eject" the screen would display "eject" for about a minute then display "loading" indefinitely. no mater how many times i powered on or off it just would not spit out my disc. However, I hit the "function" button on the player and cycled through radio, aux. etc. and that seemed to un-freeze it. I was able to eject my DVD while the player was set to radio. give it a try and hope for the best.
Jun 11, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Dvd will not eject manually or with remote tried unplugging and restarting it didn't help
It probably wasn't the best solution but it worked. I tried to jimmy open and pull out the dvd tray. When that didn't work I tried pulling the dvd out with needle nose pliers, but it did not budge. Finally I hit the eject button one last time and it worked. I hit the eject button a couple of more times and it did work. I did ruin the dvd, and haven't had a chance to play another dvd to see if it is working properly.
Nov 10, 2008 | GoVideo Go Video DVD/VCR Combo
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
DVD Stuck inTV/DVD combo unit
Same here.  Had the TV for about 6 months and had a DVD get stuck for the second time.  Used the same method of unplugging and plugging back in.  Then hitting the Stop/Eject on the side and it came out.  When plugging it back in I could hear the DVD "engage".
Jun 06, 2008 | Westinghouse SK-32H590D Television
Technical support needed can't get player to eject disc
Huncha,
I had the same problem today.  I got a screwdriver and opened the case from the back.  It was simple, just 3 black screws.  Then I looked in the unit and saw that there were 2 dvds loaded in the unit. Apparently, my daughter didn't realize a dvd was already in the loading tray when she loaded another dvd.  I gently removed the 2 disks by prying the black plastic holder open and sliding the disks out.  Then I put the cover back on and put the screws back in.  Works fine now.  I hope this helps you.  I don't think the unit has a manual eject button, but it sure was easy opening the case and looking in the unit myself.  Good luck.
Dec 27, 2007 | Samsung DVD-P241 DVD Player
Dvd eject button does not respond
Had a similar problem after loading a suspect dvd (one I had buned myself) Could not do anything - stuck at loading.
Try this :
  1. Unplug and wait 10 seconds
  2. plug it back in and wait 1 minute. DO NOT PRESS ANY BUTTONS!
  3. With the machine still in the standby state, press eject on the REMOTE. It should eject without trying to read the disk.
Good luck. It worked for me.
Dec 03, 2007 | Samsung DVD-HR720 DVD Recorder
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
