Question about Yamaha Audio Players & Recorders
I just moved and now I can't get my computer to go through my Yamaha receiver to my speakers. The CD is working and the radio is working. I am plugged into the headphone jack on the computer and the DVD jacks on the receiver. I programmed the first scene for the computer a long time ago. It says "Music Enh 2 ch" and the input at the top of the screen says DVD. Any ideas? I'm using the same cable I used before the move.
  • theduvallz Jul 18, 2009
    I found some headphones and I get nothing out of them. So the problem is in the computer. I'm running Vista. If I click on the speaker icon in the tray, the volume is up and mute is not on. Where else could it be muted? I have tried 3 or 4 other jacks on the back of the computer with no success.
    I got some haedphones and they didn't seem to work until I rebooted. Now everything seems to be working. Thanks!
  • 3,037 Answers
Have you tested the headphone jack with some regular headphones to make sure that it is sending out the audio signal? Please check that and also check for anything that may be muted, especially on the computer since the radio and the cds work. Let me know if you find anything.
Benjamin
Posted on Jul 18, 2009
I am trying to connect my Bose Wave Radio to my Yamaha RX S 70 receiver so that I can listen to the radio through my speakers. Right now the speakers are connected to the Yamaha...but radio isn't playing...
There's actually 2 ways of doing this.
Using the variable out connections on the Bose, connect your L&R channels to the desired input, I recommend the auxillary, on your Yamaha and select that input. Turn the volume all the way down on your Yamaha. Turn the volume on your Bose all the way up; then readjust the volume as desired on your Yamaha.
Optional connection; the headphone jack. Connect a 3.5mm mini to stereo plug cable from the Bose to Yamaha in the manner described as above and use the volume control approximately the same way.
Dec 12, 2014 | Yamaha Audio Players & Recorders
Volume knob doesnt work
Ironic that this popped up today. I just worked on my dads Yamaha RX-V663 today. Have you tried to see if it works on the other speaker channels. Not sure how you have yours set up or how many speakers are attached, but my dads wouldn't work on channel A, I guess it burned up. I basically just moved the speakers over to the surround sound and channel B and everything worked as usual. Oh, and turned off channel A
Jan 06, 2014 | Yamaha RX-V663 Receiver
I have a yamaha rx-v463 and a yds-11 iPod dock that I can't get to work. My iPod comes on but I can't get any sound out of the speakers. Haven't used the iPod in a long time and I feel that I don't have...
First check the yam does play other sources of sound, e.g. radio or CD. Then try your ipod in another dock to check the Ipod is working.
Then check the manual for the Yam to be sure that you have set it to a mode where it will take in the signal from the IPod. Did you switch it away from IPod source to play a DVD or a CD or the radio?
Dec 19, 2013 | Yamaha RX-V463 Receiver
Yamaha Rx-V367 Subwoofer not working, I have new Polk Audio PS10 hooked up with Y-Adayer and Subwoofer Cable to Subwoofer Jack on backn of receiver. No sound in Radio mode which other 4 speakers work, in...
Have you looked at the manual?
The NEW thing doesn't work.
Does the subwoofer work for setup? That would certify the hardware and speaker definitions are ok.
The PC has the responsibility for defining and sending out something between headphone and full-blown 7.1 though the HDMI. Check your PC sound controls and the "Information on HDMI" section of the manual.
For the radio mode, probably the only analog stereo source you have, read up on the STRAIGHT decoding mode and Sound Field programs.
May 08, 2011 | Yamaha RXV367 Receiver
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Radio Interferance on my logitech computer speakers
You may be now living too close to a radio station. Sometimes when this is the situation, anything electronic gear plugged into a wall socket can act like an antenna, thus receiving signals from local radio stations.
Mar 10, 2010 | Logitech X-530 Computer Speakers
RECEIVER WORKS FINE WITH THE RADIO NOT THE TV.
correctly connected to output on tv ? ie red and white left and white and not yellow (video)??
Dec 08, 2008 | Yamaha HTR-5860 Receiver
32 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
