Question about Proform Perspective Es Treadmill PFTL99806
The drive motor makes a noise which is louder at higher speeds
The drive motor makes a noise which is louder as the speed increase. It does this even if it runs withoth the belt. It sounds like if some parts are not lubricated and has friction.
  • luistor Jul 23, 2009
    Thank you for your advise. I also went to a couple of electrical motor shops and they also advised me to replace the motor which cost over $200. I thought that I had nothing to lose and decided to fix it myself. I did it!! It was not easy because I am not a technician or mechanic. It took me 4 hours and the cost of the bearing $11. Most of the time I spent was trying to figure out how to remove the axle from the pulley and removing the old bearing. The threadmill is now excellent! By the way, I tried to log in with the temporary password you sent me but was not able to do so. Once again, thank you for your advise.
  • 75 Answers
Bearing in the motor are bad. Replace your motor.
Posted on Jul 18, 2009
  • Franco2112 Jul 24, 2009
    Great news! Glad to help.
Loud ticking noise on driver side as speed hits 50mph gets louder as mph goes higher but noise gets quieter when mph goes down. If I do not reach 30-45 mph it will not tick, what is causing it
Noises are decieving. Cud be steering system or wheels or suspension. If ball joint fails car cud flip ovr.hav pro testdrive it. Seek a gudguy at surecritic.com
May 21, 2015 | Cars & Trucks
Revving is louder at high speeds
means your transmission is slipping . that would be your over drive and 3rd and 4 th shift solenoid
Dec 07, 2012 | 2002 Lexus ES 300
Vitamix variable speed not smooth
Some models had a weakness with the variable resistance in the rotary switch but your description sounds more like the main PCB or even the motor both of which are very expensive parts to replace.
Nov 04, 2017 | Vitamix Blenders
When I go at about 40miles(speed ) it's a loud the gears don't stick but the higher the speed the louder it get's need to kind of know what to tell a mechanic is to where to start to look.I doesn't
I would suspect it is a wheel bearing issue, if it sounds similar to a baseball card in the spokes of a bicycle, stays somewhat same pitch just louder with speed that is where I would look. Does noise go away or change when making turns?
Nov 08, 2011 | Hyundai Motor 2002 Sonata
My Epic 425 is getting louder and louder, a whirring noise, but can't seem to find maintenance help
It sounds like you have a drive motoer failing. The only other place that can be load or making noise is the front and rear roller. The rollers bearings when failing make a "popping" or "clicking" noise, and increases as you speen up. The motor "growls", and the faster you go the noise is..... well loud. The way to confirm this is to remove the motor hood, then start the treadmill on power/speed level 3. Be very carefull, and use a broom stick (wooden) to put on the drive motor while it is running. You should be able to "feel" what you are hearing. You should then raise the speed, and you will then feel the increase as well.
The replacement motor is around $200.00.
Hope this helps
Nov 12, 2010 | Epic 425 Mx Treadmill EPTL88105 !
My Hawkins 44" fan makes a humming noise when the fan is going. The faster the speed the louder the noise. With light on only , no noise. My assumption is it is electrical. Any advice would be welcomed....
Unless it is really loud, the noise you describe is quite normal. Often, at higher speeds the whooshing of the blades will mask some of the motor sounds. we have found the Hunter fans to run the quietest.
Sep 30, 2010 | Hampton Bay 56 In. Florentine IV, Brushed...
I have a whirring or griding in my drivetrain. I can coast donw a hill and let the engine idle and I still get the noise. It doesn't sound any different going around corners and gets louder as the speed...
this sounds like(no pun intended) you have a wheel hub bearing assembly failing. they will start a whirring or humming noise and then a growling or grinding noise the worse they get. from your description it is a rotational noise and gets louder and maybe a higher pitch as the vehicle speed increases. have this checked out right away so no further damage is done. they are not cheap assemblies as most GM and Saturn vehicles have the ABS sensor built into them(if your Vue has ABS).
Nov 06, 2009 | 2004 Saturn VUE
Rhythmic thumping noise with increased speed
The problem is the rear roller has a bad bearing and needs to be replaced
Mar 11, 2009 | Bowflex Treadmill Series 7
Open Questions:
See all Proform Perspective Es Treadmill PFTL99806 Questions
Proform Perspective Es Treadmill PFTL99806 Logo
542 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
