Question about Intertherm P3RA-048K Air Conditioner
Where is the model number on my intertherm split system air conditioner.
    Problem Solver:
  • 9 Answers
It should be at the end farthest away from the fan at the top right corner. If it is gone, you can us the compressor numbers to assist you in finding any other info.
Posted on Jul 18, 2009
A intertherm t3qc-030k air conditioner is how many tons?
If T3QC-030K is the model number it is 2 1/2 tons.
12,000 btu = 1 ton 030 means 30,000btu
Jun 04, 2014 | Intertherm P3RA-036K Air Conditioner
LOOKING FOR YEAR OF MANUFACTURE FOR MILLER MODEL P3RA-030K SERIAL P3D030400057
Your unit is April 2003. So it is 8 years old. P3D is model ref 0304 is year/month of manufactor. You also have a 2.5 ton system. Hop this helps. Info verified through local Intertherm distributor.
May 16, 2011 | Intertherm P3RA-030K Air Conditioner
I have a Intertherm outside AC & it was put in when the mobile home was built(1982) and I do not know what it is, I only can find the name of the manufacture, where would I find the model, & other...
mobile homes have split units, I would check the unit inside to see if it has any information. I would check all breakers inside and out, and thermostat. Hopefully it will be something simple. Good Luck Tim
Aug 09, 2010 | Intertherm P3RA-036K Air Conditioner
Intertherm 13 SEER split air conditioner fans wont turn on?
OUTSIDE FAN OR INSIDE FAN OR BOTH. IF BOTH CHECK THERMOSTAT WIRE HOOK UP. IF YOU INSTALLED NEW TSTAT CHECK FOR JUMPER ON RH-RC TERMINALS ON TSTAT BACK PLATE. IF INSIDE FAN COMES ON WITH FAN IN ON SETTING AT FAN ON AUTO LEVER THAN PROBLEM IS AT OUTSIDE UNIT. CHECK FUSES IN BOX ON OUTSIDE WALL. SHUT OFF BREAKER FIRST.
Apr 21, 2010 | Intertherm P3RA-060K Air Conditioner
No AC from older Intertherm split system
It sounds like you are low on refridgerant. Double check to make sure both fans and the compressor are running. If so then you have a refridgerant problem.
Aug 29, 2009 | Heating & Cooling
Finding model number of older intertherm central a/c
If it is not on the out side probably very weathered usually on the schematic in the unit if your wanting the age their is a model and serial number on the compressor hope this helps . Tom
Jun 25, 2009 | Intertherm P3RC-042K Air Conditioner
No cold air,system is running
ok then only other thing can be is that you are low on freon.
Jun 23, 2009 | Heating & Cooling
I need a coil for a split unit intertherm unit I dont know the model but the moble home is a 1998
That's not going to cut it. You can't just stick a coil on a system. You will need model # of furnace and most importantly the model # of the outdoor unit in order to find a coil that is an appropriate match; otherwise, you will probably end up shooting yourself in the foot and spending alot more in the long run to fix mistakes. I recomend contating a local professional to help you.
Jun 24, 2008 | Intertherm Heating & Cooling
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
127 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
