Question about Canon FAX-L900 Plain Paper Laser
Fax allows only 2 pages to be fax from outside
Hi Guys,
Could you be so kind to suggest me solution, what may cause the issue;our customers send us usually more than twa pages documents and our fax L-900 machine prints only the first two pages.
Thank you in advance.
  • Canon Master
  • 1,113 Answers
Noisy/faulty phone line could do it causing communication to fail after so many errors (need filter if ASDL), or could be having trouble picking up paper (check by doing multipage copy) or of course it is sending fax prob but I take it you mean customerssss faxssss
Thats about all it can be.
Posted on Nov 19, 2007
HP 3380 All-in-one. wont send faxes. dials, says connecting, and even sometimes starts to send page, but comes up comm error. I have vonage phone service.
Vonage claims to work with all fax machines. However, some customers report having had trouble sending and/or receiving faxes with Vonage and other voice-over IP (VoIP) providers. The difficulties are a frequent topic in help forums and even made the Wikipedia entry for Vonage. Frustratingly, the problems have been intermittent and hard to diagnose, and some customers have resorted to buying a new fax machine that better-suits Vonage’s optimum specifications. The company’s official “help” resource suggests lowering the baud rate on the fax machine to 9600 (or “slow”) as well as disabling the machine’s ECM (error correction mode) feature, if applicable. Also, make sure the fax machine is on the “standard” setting. Some users have had good luck adding *99 before dialing, as that resets the bandwidth for that call.
Vonage also allows its customers to send faxes over the Internet, without a fax machine, by uploading documents to the Vonage web site. There is no additional charge for this service if you’re on the company’s “Unlimited Plan.” Per-minute customers will see fax use applied toward their monthly minutes allowance. Hope this helps.
Apr 20, 2010 | HP LaserJet 3380 All-In-One Printer
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
SENDING FAX COMING BACK BLANK PAGES .NOT PRINTING ATALL.
If you attempt to print any kind of report from your unit and the pages are still blank there are two posibilities.
#1 The toner cartridge tape was never pulled out correctly/ the toner cartridge might be defective.
#2 A more serious cause fo the same symtom might be a defective hi voltage section in the unit. On a newer product this is not very likely
May 13, 2009 | Canon FAX-L1000 Plain Paper Laser
How do I fax from OpenOffice.org Writter??? I have a HP Officejet J5780 that fax hard copy just fine, but want to fax right from the word processor. I am using Vista Home os.
Sending Faxes and Configuring OpenOffice.org for Faxing
To send a fax directly from OpenOffice.org, you need a fax modem and a fax driver that allows applications to communicate with the fax modem.
Sending a Fax Through the Print Dialog
1. Open the Print dialog by choosing File - Print and select the fax driver in the Name list box.
2. Clicking OK opens the dialog for your fax driver, where you can select the fax recipient.
Configuring OpenOffice.org a Fax Icon
You can configure OpenOffice.org so that a single click on an icon automatically sends the current document as a fax:
1. Choose Tools - Options - OpenOffice.org Writer - Print.
2. Select the fax driver from the Fax list box and click OK.
3. Click the arrow icon at the end of the Standard bar. In the drop-down menu, choose Customize.
The Toolbars tab page of the Customize dialog appears.
4. Click Add Commands.
5. Select the “Documents” category, then select the “Send Default Fax” command.
6. Click Add and then Close.
7. On the Toolbars tab page, click the down arrow button to position the new icon where you want it. Click OK.
Your Standard bar now has a new icon to send the current document as a fax.
Mar 06, 2009 | Microsoft Windows Vista Home Premium with...
HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
Faxing multiple pages
reinstall the printer software. deleted the existing printer software first.
Sep 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Broadcast Fax Sending
Change the resolution to STANDARD. This will cut your send times by 50%
Sep 06, 2008 | Symantec Winfax Pro 10.03 (winfax10.03)...
Fax machine will send faxes but will not receive any
The normal problem with a fax that will not receive calls it the phone line.
The Line Voltage, or current may be low, or the signal ( DB loss) may be affecting it.
Let me give you an explaination. When you send, you physically connect to the phone line, make the dial tone and whatever is there, it goes out over the line.
When you receive a fax, it is like a remote control, with a remote you need good batteries to generate enough signal to turn on a product.
With a fax, you require an electrical signal, like a remote control to activate the receive capability. Low power, voltage or current. or static, will not allow it to receive, just like a remote with a bad battery will not turn on a product.
Issues can be. The phone cord between the fax and the jack. A bad jack, something on the outside line.
Using a digital phone line, or having another device on the same phone line drawing down the line, or picking up. A credit card machine, answering machine, even another phone can cause issues. If on a shared phone line, disconnect everthing but the fax and have someone send you a test fax. See if that helps.
But more than 90 percent of fax will send , will not receive issues are phone line related.
Apr 11, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Doesn't receive from two fax numbers outside the UK
I would suggest there is nothing actually wrong with your machine, as you can indeed receive faxes from other parties. The problem mostly likely lies with the equipment and/or lines of the sending party. One thing you might suggest to them is to turn off ECM (Error Correction Mode) and/or lowering the sending/receiving speed of the machine - preferably the sending speed of the sending party.
Nov 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Fax sending problem
It sounds like you have a few problems. First, the comm error usually means there was a problem communicating with the other fax. This maybe caused by a phone line issue, or a bad connection. You will have to replace you ink but that does not have anything to do with your sending issues. As far as the pages getting stuck, the separation pad under the top cover should be cleaned. If you lift up the cover where you load your pages to be sent, and look in there(on the backside of the keyboard)you will see a flat square rubber piece. Clean it thoroughly with a rag and some rubbing alcohol. Also clean the rubber rollers as well. Good luck John
Jul 03, 2007 | Brother IntelliFAX 1840C Plain Paper...
Canon FAX-L900 Plain Paper Laser Logo
95 people viewed this question
old marine
old marine
