Question about GE Refrigerators
TOP FREEZER IS 20+DEG AND BOTTOM IS 54+ DEG. WHAT IS THE PROBLEM?
I HAVE WHIRLPOOL REG.
  • GE Master
  • 1,606 Answers
Probable fan problem in freezer . Would have prefered more information though . Is there frost on the rear wall of the freezer ? Are your coils clean under refrig ?
Posted on Jul 19, 2009
Lg lfx25960st not cool enough
1. What are your controls (freezer & refer) set at?
LG recommends 0 deg for the freezer & 37 deg for the refer.
2. The way a modern refrigerator works is, the freezer is cooled directly and cold air then is blown into the refer section. The incoming vents in a French door LG are at the back, top. Return are at the bottom. Make certain that nothing is blocking these vents and than the refer has good air circulation.
3. Vacuum the coils at the back of the refer. A large build up of dust, dirt, animal hair etc. will affect efficiency.
Apr 14, 2014 | LG LFX25960 Bottom Freezer French Door...
Freezer temperature not uniform
If you hear the fan then it might be sticking on defrost mode.
Mar 26, 2014 | Amana 19.6 cu. ft. / 555 liter Upright...
Freezer not uniformly cold
Check the fan vent to see it's not blocked or frozen. Sometimes a defrost will clear ice temporarily, but it will happen again if you have a bad fan.
Whirpool gx2fhdxvy04 coils entirely forze over. thawed removed ice cleaned all drains and lines. pluged back in is cooling fine, but compressor has been running now continually all after noon. Freezer 5...
It is normal for the fridge to take a while to recover the cold temps after a manual defrost but if you did not test or replace the 12729128 Defrost Heater and the W10165425 Defrost Thermostat you will need to do the manual defrost again until you do replace, Thanks John Tripp Appliance 911
Feb 17, 2014 | Whirlpool GX2FHDXVY Energy Star 22 Cu. Ft....
Freezer section 26 deg f. refrigerator section 58 deg f with both dials set on 3. refrigerator section not cold even if dial is set to 4 or 5
when you open the freezer door do you hear the fan blowing,also is there any like snow or frost on the freezer wall inside the freezer,touch it and make sure or was the door left open?is there frozen water droplets on the food packages and on the racks,let me know what you find and send the model number,open the fridge door and look on the left side wall near the ceiling
Sep 07, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator runs, not cooling
Sounds like you have a defrost problem. the easy way to check this is to turn the unit off for 24 hours doors open.
Then turn back on and if it starts cooling ok it is a defrost issue
Jun 06, 2017 | Kenmore Refrigerators
My galaxy ice maker stopped working. At first i thought it was just jammed. We cleared it of ice. We thought maybe the drawer wasn't put back in correctly, took it out and put it back. Worked for a little...
ck the temt of freezer . it must be 15 deg or lower . sounds like it 20 deg and is having a hard time. set freezer to lower tempt and clean the coils undr neath and make sure the fans both top and bottom are going . as no air flow no ice. or poor cooling .. **** hope this helps / feed back pls .
Dec 23, 2009 | GALAXY Microsystems 25.4 cu. ft....
Top Freezer won't freeze--blows 50 Degrees constantly!!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. the noise you hear is probably the klixon cycling because the compressor is hot. You can put a fan blowing on the condenser coil and see if this helps.
Good Luck,
Gilsh
Nov 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Top freezer of whirlpool frosting up bottom notgetting cold
If your fan motor is blowing then I would say you have a defrost problem. How about a good old apartment top mount ice box manual from whirlypool?
TOP MOUNT REFRIGERATORS
Nov 06, 2009 | Whirlpool (ET8FTEXSQ) Top Freezer...
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
