Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Turns off when a signel is connected to it
When i power the monitor up it seems fine but as soon as the 15 pin cable is plugged in the monitor turn off , this even happens if the 15 pin cable is not plugged in the other end. can it be fixed?
  • 180 Answers
Try to connect LCD to another computer.
If it is ok something then went wrong with your PC.
Either your display card defect or the CPU need to reinstall the OS (operating system).
Posted on Apr 21, 2008
How do you use external monitor facility? Aged friend has Versa m370 and needs larger screen due to poor eyesight.
does your friend laptop supports dual monitor if does you need another monitor a larger one so that your friend wont have a problem with his poor eyesight. But if it doesn't support dual or multiple monitors do the same buy a new monitor a larger one.
Jul 01, 2011 | Computers & Internet
Cannot read the model number (chinese) I known i have a flat screen monitor 20 inches from DELL 2004 I want to connect it to my Inspiron 1100 .I need instructions this an handme down so I have no...
Since the cable you're describing is a VGA cable with the 3-row, 15-pin configuration, it will be the 1:D-sub selection. The DVI choice is for HD TV or a display card with HD capability. The S-Video is more commonly used for higher clarity video signals--less than HD of course, but approximately 15% to 20% sharper than a co-axial cable signal. (Reason: co-axial cable has all the color sigs squashed together while s-video splits them out into separate feeds.)
Sep 15, 2009 | Dell Computers & Internet
I've fried my monitor - Won't power on
It will be almost impossible to find these components unless you are in Taiwan.
Feb 15, 2009 | LG Flatron 795FT Plus Monitor
My monitor will not turn on.
Since you just reconnected it to a computer, double check to see that all connectors, power and signal are well plugged in. Make sure you have not bent a pin (normally 15 pins) on the signal cable connector, where it connects into the computer video port. Make sure there is only one video port on the back of the computer, if there are more try them too. You may have to reboot after switching the cables over.
Electronics do not store well in high humidity. If this is a CRT monitor, it is probably not worth the money to mess with, since you can buy a used replacement very cheap.
Nov 17, 2008 | HP V70S 17 in. CRT Monitor
Monitor black
Try looking at the Monitors Plug, Look directly into the Plug, you should see 15 small pins inside the plug.
Sometimes one or two of these pins get bent over and no longer makes contact. If you do see a pin than is not pointing straight out like the reset, the best thing to do is to use a small pair of needle nose pliers to gently straighten the pin. Be very careful becouse once a pin is bent it can break easily.
Oct 18, 2008 | Computers & Internet
Dell E151FPb 15" LCD with power LED blinking.
The problem may be a loose connection. When I turn on my monitor, the green light blinks and a flickering white screen appears for a brief second every time. There must be a loose connection on the power board which may be causing this. The easiest solution is to tap at the back of the monitor. This will reconnect the loose end and the monitor will work fine until it gets disconnected again. I will open my monitor soon to find the real problem. But it will take some time to find it.
Aug 17, 2008 | Dell E151FPp 15" Flat Panel LCD Monitor
Hannspree tv
This is a very difficult question to answer without knowing more info, but here goes:
Check the power cable, there should be only place to plug it into. This may be one of several styles depending on your model, usually a 3 prong female (just like your PC's power cable) connector, or a single pin female connector (looks male but has a hole in the center) will connect to the back of the monitor.
If you get power, but no image: VGA connections will use a large blue connector with 15 round pins, 3 rows of 5. DVI will be a large white connector with slotted pins, with varying amounts of pins depending on the type of cable (analog, digital, or both). HDMI will be a small connector that resembles a large USB connector. You may also be using a composite or component cable, which will be color coded to the ports on the monitor.
All styles of connectors will physically only connect to the corresponding port. Check all connections and make sure they are all secure and connected to the correct locations on the monitor. Doing this should resolve your issue.
May 12, 2008 | Hannspree HW191D LCD Monitor
Monitor no signal
Check to see if there is more than one 15-pin monitor connection on the back of your computer. If there is, try plugging the video cable into the other one.
Is this a new monitor? Was it working before this? Does your computer sound like it is starting up normally?
Feb 01, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
81 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
