SOURCE: how to clean waste toner bottle
Disposal Tank is on the Process Unit... you will have to remove the screw on the left side then pour it out on the bag...
SOURCE: I have a message that
After looking on the net if your printer is under warranty, you should call Kyocera Service Rappresentative or an Authorised Service Centre as Kyocera is not releasing how to empty or clear the waste toner box and if you do you will woid the warranty.
SOURCE: i already replace a new toner but there an error msg AP
Hi
The AP message indicates thet the dev is so low in toner that the machine has to go into a full cycle mode to get the toner levels up.
The error code is telling you that one cycle is not enough. you will have to turn the copier off/on and cycle it at least one more time....more if neccessary
SOURCE: Waste toner near full?
You can empty the waste chamber on the image unit by removing the screw from both ends of the unit, pull the ends off and empty it out. It's a messy job so have a good plastic bag and a toner vacuum if possible. The message might stay on awhile but will disappear with time. The alternative is a new image unit.$$$$$$
