Question about HP PSC 1610 All-In-One InkJet Printer
I get an error on my printer saying the color ink cartridge is not the correct
    President:
  • 672 Answers
Try pulling the ink cartridge out and clean the electrical contacts with a damp paper towel(use water only). Try the same method on the printer connecters for the ink cartridge. If this doesnt work, shut down the printer and power it up again. If this also fails, its a possible defective or clogged cartridge!! Hopefully this helps!!
Posted on Jul 18, 2009
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
      For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
Cartridse error
If you see a message saying that you have an incorrect ink cartridge, a flashing cartridge light meaning a bad color cartridge or you are told to remove the color cartridge, you should follow these steps to correct the problem if you are sure you have installed the correct color ink cartridge.
Instructions
Reinstall the ink cartridge
1. Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
2. Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
3. Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, continue reading.
Wipe down the cartridge contacts
2. Remove the cartridge an use a clean, lint-free, dry cloth to gently wipe the contacts.
3. Wipe from the top of the contact to the bottom. Do this for each contact.
4. Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
5. Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, continue reading.
Reset the Officejet printer
1. Turn on the HP printer.
2. Unplug the power cord from the back of the printer and wait one minute.
3. Plug the power cord back into the printer. Press the on button and hold until printer turns on.
4. Print a test page to see if this has fixed the problem. If not, you will need to buy a new color ink unit.
Jun 04, 2011 | HP Officejet 5610 All-In-One InkJet...
Printer says "incorrect alignment" and
Possible causes of the error you got can be that one of the ink cartridges is low or out of ink or the paper has already been printed on or is colored paper or the ink cartridge is defective.You need to
examine the paper the alignment page was printed on. Does the alignment page print correctly?You need to perform an print cartridge cleaning procedure and Try to align the page again.
Mar 14, 2011 | Computers & Internet
Cartridge alignment problem - it says to remove tape from cartridge or troubleshooting. There is no tape on the cartidges.... HELP!
Are you using Dell Series 9 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 9 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 9 color cartridge.
You are using Dell Series 9 ink cartridges, correct?
Dell Series 9 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 9 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
Black cartridge = black side(left side) Color cartridge = color side(right side)
Photo cartridge = black side(left side) Color cartridge = color side(right side)
It is possible to get a Dell Series 9 cartridge with a bad sensor. Contact the place of purchase for a replacement.
Rick
Jan 09, 2011 | Dell 926 All-In-One InkJet Printer
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
Sep 18, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Ink
  1. Buy only genuine Dell replacement cartridges. Dell states their printer cartridges cannot be refilled with ink and that only their cartridges work in the printer.
  2. Bring the cartridge carrier of the printer to the center so you can access the ink cartridges. Open the cover of the printer and the carrier slides to the center. Make sure the printer is turned on.
  3. Remove the old black ink cartridge to use the color cartridge. If you allow the old black cartridge to remain in the printer, you will get error messages that the ink is low. The printer may also keep reverting back to the black ink as the default color when printing.
  4. Open the package of the new color cartridge carefully. Remove any blue packing tape that's on the ink cartridge. Take care not to touch the gold area or you could damage the cartridge. Insert the new color cartridge into the correct slot in the printer, the right side of the cartridge carrier. The ink cartridges aren't interchangeable; they need to be placed in the correct slot.
  5. Close the cover on your printer after installing the color cartridge. Run a print test to make sure the color cartridge is installed correctly. Use the Dell Ink Management System to monitor your printer and all-in-one functions. Thanks Thiru
Jun 15, 2009 | Dell 810 All-In-One InkJet Printer
Cannot print true color.
How do I resolve the error message "Calibration Page Not Found"? Error code: 3610 Question : How do I resolve the error message "Calibration Page Not Found"?
Answer : To resolve this error condition, correctly position a calibration page on the scanner. See the User's Guide for more information. How do I resolve the error message "Cover open"? error code : 3501 Question : How do I resolve the error message "Cover open"? Answer : To resolve this error condition, close the access door. The printer will not operate while the door is open. How do I resolve the error message "Color ink cartridge missing or not installed correctly"? Error Codes : 3511 Question :
Answer :
To resolve this error condition, reinstall the ink cartridge:
  1. Remove the color ink cartridge:
    1. Open the printer access door by lifting from the front center of the unit.
  2. Check the two electrical contacts on the ink cartridge for small marks, which should appear if the cartridge was installed correctly.
    If the electrical contacts do not have small marks:
    1. Reinstall the ink cartridge, making sure you press down on it until it clicks into position.
    2. Remove the color ink cartridge, then check the two electrical contacts on the ink cartridge again for small marks. Repeat if necessary.
    3. Reinstall the ink cartridge.
  3. Close the printer access door.
NOTE: See the User's Guide for more information about removing and installing the ink cartridge.
If the error persists:
  1. In the KODAK All-in-One Home Center, select the Help (?) icon.
  2. Select Maintenance.
  3. Select Firmware Upgrade, then follow the prompts to download the latest version of firmware, free of charge.
From Kodak support:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=9104/7269&pq-locale=en_US
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I just installed a new black ink. The error message keeps on saying wrong color cartridge installed. I replaced with the correct one for my officejet v40. Black 15.
did you try changing the color cartridge too? I had problems with ink cartridges that were not HP cartridges.( not made by HP but some other co.)
Dec 05, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Printer error
you may need to do a clean heads and nozzles on that HP..try that first.
Apr 25, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
