Question about Brother ML-300 Typewriter
I bought a --brother AX-400 electronic typewriter at yard sale... please help me set left and right margins...
Move the carrier to the desired position for the new left or right margin using "backspace" or "space"
To move beyond the position of a current margin, first position the carrier on the margin and press "alt +m rel"
When the carrier is on the desired position, press "alt + l mar" (if you are setting the left margin), or "alt + r mar" (if you are setting the right margin.)
The minimim distance between the left and right margins is two inches
Posted on Dec 31, 2009
How to reset the margins on Brother EM-530
On most electronic typewriters you change the margins by pressing the code button and holding down the press r margin or l margin on the key board. You want the carrier to be where you want the margin set. To set margins beyond the right or left margin move the carrier to the margin and press margin release to go past the margin. Then press code left or right margin.
Jun 30, 2014 | Brother EM-530 Typewriter
How to set right/left margins on brother AX110 electronic typewriter?
space or backspace to the place where you want the left margin. You may have to use the margin release key to go past the present margin. When you get the carriage to where you want the margin, depress the left margin set key. Some have L mar and R mar keys, also some use the code key and another key to set.
Apr 14, 2014 | Brother GX-6750 Typewriter
How to set right and left margins on a brother AX110 electronic typewriter
Alt + (5%) set the right margin and alt + (4$), these are your top row of numeric keys.
Apr 14, 2014 | Brother SX-4000 Typewriter
I have an SX-4000 Electronic Typewriter and use it from time to time BUT I do not know how to reset the margins....basically expand them beyond the norm. Please help - I did do the ALT and then the 4 or 5...
Try this procedure to set and adjust the margin:---- Use the "Space" and "Backspace" keys to set the margins by positioning the carrier where you want each margin. Press the "Alt" key along with the "L Mar" or "R Mar" key, depending on which margin you are setting, left or right.Press ALT with L Mar key to adjust margin on left side.Press ALT with R Mar key to adjust margin on right side. ----------------- For more help.Click this link below and check page number 11:---- http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SX4000_EN_219.PDF ------------
This should help.Thanks.Helpmech.
Jan 05, 2011 | Brother SX-4000 Typewriter
How can I change the margins? for Brother SX-4000
Move carrier with the backspace or the spacebar.
Press and HOLD [ALT] while pressing the [4/$] key.
The left margin is now set.
Press and HOLD [ALT] while pressing the [5/%] key.
The right margin is now set.
Hope it helps
Oct 06, 2009 | Brother SX-4000 Typewriter
My electric typewriter the AX-430. I have lost the Manuel and cannot take the format off, it only types to the center of the page and goes no farther. any help?
Sounds like you need to reset your right margin. Spacebar to the right as far as the carrier will go. Hit the Margin Release key and then continue to spacebar to the right where you want your right margin set. Press "Code" and "Right Margin Set" (or similar name, not sure of exact key name here) to set your new margin. Should work ok now.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Apr 15, 2009 | Brother Office Equipment & Supplies
How to install min L MAR on the Brother Typewriter AX-450
move the printhead to where you want the L MAR set then hit the L MAR button, if you want to move to the left of where the L MAR is set, go to the L MAR by backspacing or  the return key, hit the MAR REL button and backspace to where you want the mar set and hit L MAR.  the right margin works the same way
Feb 25, 2009 | Brother Office Equipment & Supplies
I have a typewriter brother I have a typewriter brother ML300 and I cant figure how to ajust the margin.....please help
Left Margin:
Move the carrier to the place you want to set the left margin by using (SPACEBAR) or (BACKSPACE). If you need to move outside the current left margin, press (ALT) + (M REL) (3). Press (ALT) + (L MAR) (4). The left margin is now set.
Right Margin:
Move the carrier to the place you want to set the left margin by using (SPACEBAR) or (BACKSPACE). If you need to move outside the current right margin, press (ALT) + (M REL) (3). Press (ALT) + (R MAR) (5). The right margin is now set.
Hope this helps!
Feb 06, 2009 | Brother ML-300 Typewriter
Setting Margins
move the carrier to where you want the mar.set then hit the R MAR or L MAR key.
to move the carrier beyond the margins hit the MAR REL key
Nov 06, 2008 | Brother EM-430 Typewriter
Help with Typewriter
hold down the code key and press the margin release, to set margin, just hold code release margin, space over to where you want it and then press Margin set, left or right.
Jun 05, 2007 | Brother GX-6750 Typewriter
Brother ML-300 Typewriter Logo
485 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
