SPARE NUMBER IS 18300-GGP-901
SOURCE: 2003 GMC Sierra 1500 missing spare tire removal tools
try junk yards .com
or if you no anyone with a garage you can make one
or just cut the cable and put the spare in the bed
SOURCE: replacing spare tire winch 2004 chev trailblazer
I have a '02 TrailBlazer and I had the same problem. When I got a flat and went to change the tire on the side of the road I was not able to get the tire off the winch. Luckly, I have AAA and the driver knew the trick to getting the tire free. The process involved lowering the tire as far as it would go and then kicking it. Wind back up and repeat until the winch free's itself.
When I took the car into the shop to get the tire fixed and the have the spare put back on the car, they were not able to get the winch free enough to put the tire back on. They said that is is a common problem with this mechanism and suggested replacing the winch system (estmated parts and labor $215). From what I can tell the winch accumulates rust up in the cable and locks up.
SOURCE: Can't release spare tire retainer
push the tire up with you knee and move the hang down rod over so the tire can drop.It can be a little hard.
SOURCE: The cable for the spare tire on my 2006 1500 works
Important: If the spare tire hoist has been
fully raised without a spare tire in place, the secondary latch
mechanism may have become engaged. If this has occurred the hoist will
not lower and the following steps will need to be
followed:
SOURCE: My honda odyssey touring does
2005 Honda Odyssey TOURING models originally came with Michelin PAX run-flats and eliminated the traditional dough-nut spare. If your van no longer has run-flats (look at the tire size) then your van has already been De-PAX'd...count your lucky stars because PAX tires run about 300 a tire plus!!! If you have been De-PAX'd then you will need a donut spare (T135/80D17) this goes into the spare tire space located behind the 3rd row of seats. this Site has everything you will need for the spare http://www.hondapartworld.com/1534_SPARE-SHJ
