Question about Garden
Oil coming out of the carburetor of my Honda Harmony 215 mower
I have oil coming out of the carburetor of my Honda Harmony 215 mower during operation. Worked fine for a while, then thick smoke from exhaust and oil from carburetor air intake area. I had not previously tipped the mower for service. Is this a head gasket? How should I proceed to diagnose and repair?
  • 22 Answers
Unless the ground was a steep slope while mowing or the mower was tipped over 35 degrees or more in any direction except with the handle bars down (spark plug up is ok), it will most likley be a blown head gasket between the pushrod gallery and cylinder. remove the head and get it re-faced then assembly with new gasket. valve adjustments are 4 thou inlet and 6 thou exhaust
Posted on Jul 20, 2009
  • 661 Answers
It could also be overfilled with oil. I am working on one right now that someone overfilled with oil and all it does is chug and miss every other stroke making it an 8 stroke.lol. the filter is soaking wet with gas and oil I bet it runs fine soon as the air filter is removed.
Posted on Nov 29, 2009
Lawn mower where is the serial number on a honda harmony 215 SX
on the deck behind the engine. if it's not there then it's gone. if your the original owner a Honda dealership can look up the name and get that info
Feb 20, 2017 | Honda Garden
My Honda hru173pu mower blows white smoke and there's oil on the plug I haven't overfilled the oil do u think I need new engine rings
That is definitely a sign of bad rings. Sometimes people turn the mower on its side, the wrong side and then oil slips past into the cyclinder . Spray some carburetor cleaner into the plug hole then reinstall the plug. Start the unit up and see if it burns the oil from the cyclinder, give it a few minutes. If the problem goes longer than a few minutes then yes, bad rings.
Oct 08, 2015 | Honda Garden
Can I use Lawn mower oil Honda 10W 30 instead of Sae 30 oil
Yes. Note that it is for cooler seasons; during hottest days of summer you want to stick with the heavier oil as it will thin out considerably. I would this especially for equipment doesn't have an oil pump but are oil dippers. Now you wanting to use the equipment year round then I recommend going with the synthetic 5w30 blend as it is more stable throughout the equipment temperature range.
Dec 19, 2014 | Honda Garden
What oil and oil filter do I use for my riding lawnmower.
30 weight oil is fine. as for the filter..I would suggest that you bring it to a shop and match it up, or go on line to manufacture.
Oct 09, 2014 | Garden
Honda Harmony II HRR216 won't start
Check for spark of smell of gas on the plug when you try to start it. That will tell you if it is fuel or ignition
May 18, 2013 | Garden
Honda harmony 215 sx blades will not engage
Tighten blade nut. Shaft maybe bad, bad motor.
May 06, 2012 | Honda Garden
Snapper 25 hp (kohler engine) mower
When checking the oil donot put dip stick clear in just let it set on top then pullit to check oil.rreplace it and tighten. Your putting to much oil in it.
Apr 30, 2010 | Ford Tractor 8n Front Emblem
My honda harmony 215 lawn mower starts but then shuts down immediately. Carb cleaner fires it up again but then dies.
most gasoline today is being blended with ethanol and is the core source of most outdoor power equipment with starting and stable running after being stored for the winter. The ethanol gums up much quicker than traditional gasoline. One product that I used was from Walmart and made by the same company that makes Stabil fuel products. It is called Start. Mix with up to 1 gallon of gas(I placed directly into my Honda Harmony 5.5 mower gas tank and ran while mowing and it cleaned the carb without having to remove it. It is running as it did when new. Worth a try
Nov 04, 2009 | Garden
I have an older Harmony II HRT 215. The drive
the best thing to do is take the model number and order a belt from honda which will be the right size and thickness
Aug 09, 2009 | Garden
Garden Logo
1,954 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
