Question about Whirlpool EL05CCX 4.3 Cu. Ft. Compact Refrigerator Including Full Size Storage Door and Freezer Comp...
My son has a Whirlpool EL05CCXJW 4.3 cu. ft. refigerator the plastic hinge-pin for the freezer door broke on the controles side.The part came without any instructions on how to remove the old piece or how to install the new one. Can you help? Thanks Larry T
5 Suggested Answers
SOURCE: WHIRLPOOL 25.3 CU.FT MODEL ED5FHEXNT00
Possibly freezer drain blocked causing ice build-up behind back freezer wall. This internal wall should be accessible by removing screws.Check fan motor in that area is working and also check that all door seals have no cracks or tears. This can cause ice build-up and motor to run longer than normally. benham's suggestion another possibility.Naturally have power off when dismantling anything.
Posted on Jan 11, 2008
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
Greg20
  • 149 Answers
SOURCE: The plastic piece that holds the pin for the ice dispenser door
not repairable..have to replace whole door..stuff a rag in the hole/buy door/or get a new refrigerator...sorry. Greg
Posted on Jun 11, 2009
nnesmith
  • 162 Answers
SOURCE: whirlpool pin retainer is broken on ice dispenser
this is easy. there is a small area beside where the piece broke off. bend a small peice of metal coat hanger at a 90 degree angle, (this is so you can make your new hole on the correct line) heat the end with a lighter, burn a smallhole thru this area beside where the previous hole existed. now throw away the old pin that you were using and use a piece of coat hanger cut to the right length. on one end bend about one half inch to 90 degree angle, feed thru new hole and thru your spring and flap and thru to opposite side hole and lastly make small bend to keep wire from sliding out. ta da, fixed. problem solved for about two cents. i have successfully repaired many of these doors.
Posted on Jul 08, 2010
Does anyone know how to replace the hinge DA61-04866A on a Samsung french door vertical panel
unclip the plastic cover off your door hinge and unscrew the screws on your door make sure you leave the top screw in just a bit so you can take it out with your fingers before you drop the door ok same for both sides
Jan 22, 2015 | Samsung RF263AERS - 26 cu. ft. French Door...
Light switch
It should be near the hinge of the door. It could be within one of the hinge sand is activated when the door is lifted or lowered.
Feb 02, 2013 | Whirlpool 14.8 cu. ft. Chest Freezer...
Dimensions
This model is a 25.6 Cu. Ft.
Height to Top of Hinge: 69 1/4"
Height to Top of Case: 68 3/4"
Case Depth w/o Door: 28"
Case Depth less Door Handle: 32 1/4"
Case Depth w/ Door Handle: 34 7/8"
Depth w/ Fresh Food Door Open 90°: 50 1/16"
Width: 35 3/4"
Width w/ Door Open 90° w/ Door Handle: 42 3/8"
Air Clearances - Each Side: 1/8"
Air Clearances - Top: 1"
Air Clearances - Back: 1"
Approximate Shipping Weight: 360 lbs.
Capacity
Total: 25.6 cu. ft.
Fresh Food: 16.02 cu. ft.
Freezer: 9.59 cu. ft.
Shelf Area: 22.4 sq. ft.
Dec 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I was given a Whirlpool ET1FTK 20.8 cu ft refrigerator/freezer. Door frame going thru is 29 inches. Need to take off doors of fridge to get in house. Anything you can send me. Don't have any of the books...
Start at the top and remove the hinge (5/16 socket). Slip the door off and remove the center hinge. Slip the lower door off and remove the lower hinge. Now is the time to reverse the door swing if it needs it. Move the handles to the other side and reassemble with hinges on the other side if you do.
Eric
Nov 03, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
How do i change my freezer door to open the other way
you will need to take the upper hinge off first, then the door will lift off the bottom hinge. Then take off bot hinge and move both hinges to the holes on the other side. As far as the handel goes, you may need to flip it over or switch the handel to the other side
Oct 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Fan Noise
There should be 4-6 screws holding it on. They may be covered with plastic plugs. just pop those out.
Jun 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Jun 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer staying cold but defrosting on Kenmore Refrigerator dripping into bottom frig
I bought kenmore refigerator 21 cu.ft. year ago, but recently on top of freeze door side produces ice would you please tell me what's happen and how to prevent.
Sincerely,
Tim Kao
Jul 09, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
