Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Oil not getting to chain
The oilpump works,and I've replaced the output oil hose.The oil backs up behind the plate. Is there a way to insure a seal to the oil pump?
    Problem Solver:
  • 10 Answers
Check that the oil gallery in the bar are clear.blow out with air if you have it.
Posted on Jul 26, 2009
How.do/i.remove.oilpump
well you failed ot mention the make and model so let me say this, most chainsaws oil pumps are easy removed by taking off the bar and chain , this requires the removal of the clutch cover not a big deal you neeed to take that off to get bar and chain off , then it's a quick twist of a phillips screw driver and out it pops , dont let that little hose go fall back inside unless you enjoy fishing , cus your gonna be fishing for it back , i use a lasso ! of crabbing line string on the hose to keep it close up top
, dont forget to clean your bar oil passage out of saw dust !! i like brakeclean for this job , but dont spray on paint job !!!
Feb 28, 2015 | Garden
Husquavarna 455 chain oil problem
is the tin plate on the right way?(not blocking the hole)did you change the bar and the replacement blocking the oiling hole
Aug 19, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
My Hoover brush spins, but doesn't have very strong suction. I've checked the filter, tubes, but it seems as though something is stuck inside. Can you tell me how to check behind the roller to...
To get the roller out.Turn the machine upside down.You will see some screws.Remove them.That allows you to remove that plate.The roller will just lift out.Some have a cap on it and can fit tight.On the back of the machine are two more screws that hold the hose on.You can take the hose off there ,if you have not already.Running a straightened out wire hanger through the hose will insure that there is not a clog you may be missing.As it is a few years,replace the belt while you have the roller out.It is on one end of the roller and the other end slips on a small wheel.It is easy to do and may improve the over all performance of the vacuum.
May 16, 2011 | Hoover U8145-900 Savvy Bagless Upright...
I have a husqvarna 137 chainsaw. The problem is with the bar oil. When the saw runs oil is flowing but where the rubber corner piece which allows the oil to flow out of appears to be just dripping the...
Hi marcus,
The bar and chain oil goes into the oil tank on the side. The oil for the engine is mixed with the gas before filling the gas tank.
Hope that helps.
Handy Andie
Mar 20, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Need to change timing chain. do i need to remove the head?
Check the vehicle manual for recommended mileage for replacing the timing chain.Locate the timing chain,you will need to replace it if the automatic chain adjuster "also known as the tensioner " is damage or worn.Drain the cooling system and disengage the negative battery cable.Undo the spark plug wires and set the No.1 piston at Top Dead Center ( TDC ) of the compression stroke. Disconnect the engine undercover,vacuum and fuel hoses,harness and connectors,drive belts, power steering reservoir,alternator and bracelet,upper radiator hose and,air doct,front exhaust tube,intake manifold collector supports,collector and exhaust manifold and distributor.Prop up the oil can and take out the front engine mounting,the valve cover and camshaft sprockets,cam bearing caps and camshafts,cylinder head bolts, cam sprocket cover,upper chain tensioner,chain guide and the chain,idler sprocket bolt,cylinder head,intake manifold and cylinder head gasket and the steel oil pan. Place a steel cutter between the steel and aluminum oil pans.Slip the cutter around the the edge of the oil pan and disengage the steel oil pan,baffle plate,oil strainer and front tube. Secure the vehicle on jack stands and place a seal cutter between the oil pan and the cylinder block,slip the cutter around the edge of the oil pan.
Aug 15, 2010 | 1997 Nissan Pickup
Chain oil is pumping into area where pipe goes under square rubber bush, but not onto the top reservior so the chain can pick it up. Behind the aluminium plate.
Hello. If you haven't done so already ,remove the bar and chain and make sure the slot in the back aluminum plate lines up with the oil outlet hole if so ok. Use a thin tool (utility knife works) and scrape inside the chain groove of the bar to clean it out.Make sure the oil inlet hole in the bar is clean. If it doesn't work after doing this you may have a cracked oil tank,disconected oil line,or worn out oil pump.
builderdale
Jan 11, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My buddy changed my sprockets on my 07 zzr 600 and its been leaking oil ever since does anyone no what it could be maybe a seal?
where is leaking oil from....behind the front sprocket??
if so your chain is TOO tight
if this is your problem, replace the output shaft seal and check drive line for abnormal wear before readjusting chain tension.
Oct 07, 2009 | 2000 Yamaha FZX 750 (Not in Europe)
Oil not circulating ? 1999 Nissan Altima DOHC, KA24DE, 200315 miles The right side guide rail to the lower timing chain shattered and jammed the oil pump. I have replaced the oil pump and both timing chain...
Well, from the oil pump it goes into your oil filter so the lines going from the pump into the filter could be clogged. check that and see. Also on most imports I have found that they have to be primed after the oil pump has been replaced. Buy a oil pressure gauge and hook it up. Disconnect your fuel and spark delivery and then just crank over your motor to make sure you have good pressure. It takes up to 30 seconds to build on some cars. hope that helps.
Jul 21, 2009 | 1999 Nissan Altima
When my saw idles bar and chain oil drips majorly and i don't know if there is an adjustment
What kind of saw is it? On my Echo, if you take the chainbrake/bar cover off, there is a screw behind the clutch that adjusts the oil flow.
Some saws have a rubber hose connecting the oiler to the oil tank. That hose could have worked itself loose or be damaged.
The oil tank seal could have a leak.
Jun 13, 2009 | Poulan Garden
Oil pump on w reg gilera runner,
its a piagio ,what else do you expect but a honda .
Oct 25, 2008 | 2000 Ford Focus
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
205 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
