There are shorcut keys by pressing numbers to be able to get into your contacts. press the Enter key or the middle button for accessing menu then quickly press: 3 and 1
Then it will open you the search field where you can type the first charters of your contact and it will show his or her number.
Unfortunatly check info service usually means your phone is moisture damaged.Especially if the screen goes blank.Check if the charger unit has turned slightly green and mouldy looking.Take off the back cover and check the battery does not look warped and also remove the front fascia and check for signs of staining on the keypad.It is not a screen problem if the logos are still appearing .it is an internal problem.If your phone is moisture damaged there is no way of repairing it.Bring it to a mobile repair shop to get it opened up and examined.hope this helps
you have to be more specific about this issue...if you are having problems with your speaker on the phone then have it replaced by taking it to a mobile service center or a professional mobile tech
