Question about Cnet CNSH-1600
Connection Problem Hi,When i plug ethernet cable , i can't see the LED of the cable on and by the way Power LED doesnt always green, it always winks.. is this something we can fix by soldering or do we need to buy a new one? and what couses this problem?thanks from now
Are you using windows service pack 3? sometimes SP3 gives problem on the lan card. Even the lan card was installed, the router or hub never detect it. That's why your hub is keep on blinking.
Posted on Aug 11, 2008
    Brigadier General:
  • 3,614 Answers
Maybe its not in the hub/router, or in your lancard has the problem. try to change the networking cable you are using it sometimes the cable has a teared wire inside, or probably the lancard or your hub does not work for the type of networking cable, there are 2 types of connection for UTP cable first is the Straight through cable and the second is the Cross Over connection. Try to mix and match the cable that you have and try to use another one instead..
Posted on Jan 15, 2008
Emachines Will not detect ethernet cable
With the machine on and the cable connected on both ends (1 to computer and the other end to the Router or Modem that needs to be powered up) look where the cable plugs into your computer. Is there a green or orange light on. There may be two. Normally one that stays on steady is the CONNECT. This one is normally green color LED. When Data is being transmitted a second LED will be flickering showing data transfer. If you have no LED lights showing directly by the Ethernet cable, try another cable. Reminder: also make sure you have power on the router/ cable/dsl modem.
Hope this helps..
Nov 04, 2012 | eMachines T5062 PC Desktop
One of the LED is orange instead of green
I also have the DGS-1008D 8-port switch and it connects fine at gigabit speeds between my 5 PC's - I would check the cabling again, as mine was plug and play. As soon as it was hooked up and switched on, I got the green light for the gigabit connection - my 100mb router (also D-Link) connects with an orange light, as it cannot achieve gigabit speed.
Hi there and thanx for the reply.
I have connected PC's with the gigabit cards to the point where the one machine connects at 1Gig. All machines connect at 1 Gig at that specific point. So it is either the cables itself or the connection in the jack itself problem
Mar 10, 2011 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
How to connect ruoter to internet
If you are connecting to either broadband cable or dsl you pretty much have the same steps. First hook up the modem (dsl or cable) with its own power cable and its own internet connection coming in (dsl will be a usually green phone cable)(cable will be a coaxial line that the cable guy already hooked up). Next get the netgear router and plug in its power cable somewhere near the modem, then plug in a preferably crossover ethernet cable to the uplink connection on the back of the netgear, should be on the same side as where the power cable went in. (and yes you can probably use a straight ethernet cable as well) Plug the other end of the ethernet cable into the only location it will go on the modem, both boxes should already be setup for use, if for any reason they do not work just pull the power on them both at the same time and wait a minute or two and replug them back in for power resets.
Oct 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
Canon Pixma ip1000 dismantle
Hi there you can try
Temporary Fix
This always works in case you need your printer for Emergency ^_^.
  1. Turn off the printer
  2. And unplug the printer power cable
  3. Press and Hold the POWER button
  4. Plug the power cable again
  5. The indicator (LED) should be green
  6. Press and Release the RESUME button, the indicator (L.E.D.) should be orange
  7. Press and Release the RESUME button again, the indicator (L.E.D.) should be green
  8. Release POWER button
  9. Windows will detect new printer and you just have to install it again.
  10. It will create a copy of Canon i320 printer. Just delete the old one and rename the copy.
  11. You are done.
Jul 09, 2009 | Cannon Canon i960 Photo Printer
Blinking Green LED on Dell Dim. 2350 won't let system stay on.
once check the ram and keep it in other slot and check it .clean the ram and keep it
Jan 13, 2009 | ASUS A7V8X Motherboard
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Toshiba laptop
Appreciate the "Ask Me".
On your post, pls try:
  • click on Start, Control Panel, Network Connections;
  • right click on Local Area Connection;
  • click on Properties;
  • click on Configure Button;
  • click on Advanced tab;
  • highlight Connection Type, in the Value box, select Auto-Negotiation;
  • you may be asked to reboot.
You could also try the 100 Base Tx Full Duplex or the 100 Base Tx Half Duplex.
It would seem that the orange led indicates a 100mbps connection while the green is for 10mbps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 14, 2008 | Toshiba Satellite 1405-S151 Notebook
I have a Compaq SR 1000 desktop set and I can't get the power to go on. When I plug the unit in a green light in the back keeps blinking. When I disconnect, hold in the power button the blinking stops, but...
Hello shapscomp
The blinking green light is likely your Ethernet card's LED. Is the blinking light located near your Ethernet (network) cable?
It sounds as though your power supply has failed. You may be able to purchase a replacement power supply for it.
Would you like some assistance in deterimining if that is the case?
Thank you
BJ
Apr 05, 2008 | Computers & Internet
For dummies
Hello, Good question..Phone line to DSL modem, Ethernet cable to WAN port on Router. If connecting a PC wired to Router, connect Ethernet cable from 1 of 4 LAN ports on Back of router to ethernet port on PC. This would be Physical connection...
It's always smart to set a restore point in case something goes wrong during installation of any program. For wireless connection from laptop or PC: install router software on computer. Reboot computer. In browser address bar enter 192.168.1.1. This brings up a window for user name and password. Enter "admin" for both. This allows you to change many settings including Changing SSID(Router Name), User name and password. Enabling WEP or WPA security. Hope this Helps, Good Luck..!!
Mar 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
Cnet CNSH-1600 Logo
377 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Marcin
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
