Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
The famous F1 problem
I have had my cabrio for 2 yrs now. Seems like that is when this problem starts. The first call I made I got this girl who tried to tell me it was an electrical problem. Not the washer. My electrical. I wish I would have check online first. My husband changed some plugs and circit breaker. Still had the problem. After I read the numerous complaints and saw their was a recall, I called again. Told this girl what I had read. She was very willing to get a service person out in 3 days. Parts and Labor covered.
Thank goodness for the internet.
  • 15,935 Answers
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
    F1(F68)-Pressure Signal Out-of-Range
    I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
    Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 is flashing on the panel, what does that mean?
    there is a huge argument and an even bigger world wide lawsuite against whirlpool for the famous f1 problem its a fault in the pcb board. in some cases though more so now days if you contact whirlpool they will arrange for a tech to come to your home and fix it for you free of charge. its an expensive repair and is common to happen again but after 3 yrs of fighting the company is in most cases happy to fix free of charge in order to stay there reputation . so give them a call in the mean time press cancell 3 times then re start wash and it should go all the way through wash till its fixed
    best of luck to you be tuff on them
    sonic boom electorincs australia
    please rank this reply if you feel it helped
    Dec 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    I am getting an F1 error right after the lid locks on all wash cycles. what does this mean?
    oh god no you poor person there is a huge argument and an even bigger world wide lawsuite against whirlpool for the famous f1 problem its a fault in the pcb board. in some cases though more so now days if you contact whirlpool they will arrange for a tech to come to your home and fix it for you free of charge. its an expensive repair and is common to happen again but after 3 yrs of fighting the company is in most cases happy to fix free of charge in order to stay there reputation . so give them a call in the mean time press cancell 3 times then re start wash and it should go all the way through wash till its fixed
    Dec 01, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    What does F1 error mean?
    Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2
    Call Whirlpool or a repair center. The number for Whiripool is 1-800-253-1301
    Nov 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 error on cabrio washing machine
    • I called Whirlpool 1-800-253-1301 today 10/15/08 and they said the F1 issue is now under a recall.
    • Whirlpool scheduled a repair service -during our phone call- to repair this under a 'recall' & at 'No Charge' to me.
    • I'll let you all know how it goes after the repair..
    Nov 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    I have the exact same F1 code problem
    Primary Control Failure
    F
    then 1 flashes when there is a primary control failure. Replace the machine control assembly.
    This was under recall last year.
    Telephone Whirlpool at 1-800-253-1301. Whirlpool has acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600 series washers.
    Tell them that your Whirlpool Cabrio washer has been receiving the F1 error code repeatedly, with the same symptoms as reported by hundreds of other customers online. You were told that there is a recall for this known defect in the control board, and are requesting that Whirlpool fix the problem including parts & labor.
    Basically - this is a problem (faulty chip) on the main controller board of the unit... and the entire board must be replaced with the updated version.
    Give the warranty a try (even if it is out of warranty)
    CLICK HERE to see the part that is going to have to be replaced.
    Aug 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio F1 code
    have the same the washer show F1 I have to hit pause start 3 time befor it will wash severly people have the same proble with this whirlpool washer it is a tiner proble i hve been tool.
    Jan 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    53 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
