Question about Toshiba Satellite Pro L300-EZ1501 Notebook
AS soon as I get past the log on screen my mouse freezes in the middle of my Laptop - Toshiba Satellite Pro 300
    Novelist:
  • 117 Answers
Next time tap f8 as you watch the bios screen load. this will allow you the option of booting into safe mode. see if you can get in through safemode to your computer. if you can then you have a software conflict somewhere. it could be a recent service pack added or a device driver that is not happy with the unit. if you get in through safemode go to your My Computer, right click and select properties. Select Tools and look for an option to check disk, select both check boxes and hit apply. it will tell you it needs to schedule the disk check. thats fine. now shut down your unit and let it run normally. it will scan the disk to see if you have a hard disk error and attempt to correct the corrupt areas. when this is all done see if you have any problems after that. if so let me know. there are about 4 other things it could be
good luck!
ruben
Posted on Jul 19, 2009
Cursor is frozen, tried allsorts to solve it. Nowt works. Using mouse with usb cable, works fine. Synaptic logo from bottom right of screen also gone. Tried system restore and it works until I log on...
Sounds like a driver issue with the touch pad. You should try and reinstall the driver.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1998675&rpn=PSLB1U&modelFilter=L300-EZ1004X&selCategory=2756709&selFamily=1073768667#
follow that link..it will take you to the driver page for your model laptop.
Mar 07, 2011 | Toshiba Satellite Pro L300-EZ1004X...
Iv got a toshiba satellite A300 and i was wondering how can i speed my my graphics card ( in any way ) whenever i try to install games and play they there is always a fault of some sort one fault that...
When you will increase the ram your laptop will be fast soon.
You can increase 4 GB maximum.
For dissemble follow bellow the link
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A355-A355D/laptop-disassembly-1.htm
Maximize your Toshiba Satellite A300-ST6511 mobile computing power and add more memory. Trust PRO Memory Upgrade to provide dependable expansion options for your laptop or notebook with a Toshiba Satellite Small Outline DIMM RAM upgrade.
  • Your Toshiba Satellite maximum RAM capacity: 4GB
  • The Satellite A300-ST6511 has 2 memory slots or sockets
  • This Satellite module upgrade PIN count is: 200-PIN
  • The memory speed is: DDR2 800MHz, PC2-6400
  • The DIMM type for your Satellite A300-ST6511 is: SODIMM, SO-DIMM, Small Outline DIMM
  • For4 diassamble the
Hope it help you.
Jan 08, 2011 | Toshiba Satellite A300-ST6511 Notebook
Toshiba satellite L300 freeze when adaptor plug in.
This is a middle pin issue, you will find the laptop doesn't charge either but will power the unit, if the power is connected, the laptop will hang and use reserve resources, if you unplug it, the machines performance will dramatically increase.
replace your power adaptor and all will be fine, i have had the same issue.
Sep 02, 2010 | Toshiba Satellite Pro L300 Notebook
My Father's Toshiba Satellite Pro A120 laptop is
about the icons moving, it is because of the resolution... when you plug in your laptop to a wide or bigger screen it changes or adjust the resolution so it would fit in the screen...
Nov 22, 2009 | Toshiba Satellite P300-ST3712 Notebook
Hi, I have a problem with my laptop when I type the password and try to log in it says wlcome and it takes a 10 second load then none of my files or anything shows up expet for a dark screen with my mouse...
Hello
Thank you for using
FixYa for your problem
Ok,
Does the unit start in safe mode?
do a system restore back a few days
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Toshiba Satellite Pro L300-EZ1004X...
Laptop has trouble staying on and when it does the mouse freezes up as soon as desktop is loaded
1. remove all unnecessary items from the startup
2. update mouse driver
3. try booting Windows in safe mode if things work OK there,
4. try booking with more drivers.
Sep 13, 2009 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite L310 problem , display cannot appears
If the screen went blank after the driver install, sometimes clicking the mouse on the screen will bring the picture back. It sounds like the monitor is having a conflict with the resolution the driver is throwing out. Reboot the laptop and when you see the Toshiba splash screen, tap F8 until you see the multiple boot menu. Scroll to Safe Mode with networking and reboot. If the screen comes up, go to the control panel > System > hardware > display adapter > click on the plus sign and double click the reported adapter.click on driver tab and select roll back driver > click yes to any prompts and click ok. Reboot normally and see if that clears the problem.
Sep 07, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba driver
as there are several different l300 model you will select the right one manually http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp# click downloads - choose portables - satellite pro - and select yours
Mar 22, 2009 | Toshiba Satellite Pro L300 Notebook
Reset password on toshiba satellite pro a200
Which operating system are you using?????????
you could set a password in the BIOS, but as far as a operating system password goes, it would be difficult, at best, to reset a password without being logged in first.....
Jun 04, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba Satellite M45-S351 PC Notebook
cutemah, Is your cd/dvd internal or usb? Have you tried to login using safemode? When the first Toshiba screen appears press the F8 key. Choose safe mode. Since you say the cd/dvd isn't being recognized that too may be the problem. Try removing the cd/dvd player and see if the machine starts. Is the error code only 0x57 or is there more? It is sounding more hardware related than software related. What program are you using to format the hard drive? Send me a little more information please. Let me know what happens. Good Luck, Tim
Mar 14, 2007 | Toshiba Satellite M45-S351 Notebook
Open Questions:
Toshiba Satellite Pro L300-EZ1501 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
