Question about Maytag SkyBox MBV1976A Beverage Dispenser
Compressor/unit runs constantly but does not cool.
Looking for any guidance. Have had the machine for about 5 years with minimal problems.
Thanks in advance for any assistance.
  • steve
    steve May 11, 2010
    Most SKYBOX machines have failed. They are not field serviceable.
    President:
  • Maytag Master
  • 1,922 Answers
Is it keeping the inside contents cold and or frozen, if not possibly condenser coil needs cleaning,also if its in a very warm place and you have no problems other than that its just trying to keep things cool and has to run longer to do so
Posted on Jul 28, 2009
I have an gss221ibma side by side. the freezer no longer freezes but the refrigerator works. Also around the doorframe of the freezer it is quite warm and sometimes hot. please help.
Hello, pull the unit out away from the wall remove the cardboard or metal cover down the bottom which will give you access to the compressor area. Assure that the compressor fan motor which is the fan that cools the compressor is running if it is not then you will have to replace the compressor fan motor. Unplug the unit until the compressor cools if you leave the unit plugged in for a long time you can cause damage to the compressor itself. . If you do not have another place to store your food until you get the new compressor fan motor leave that cardboard or metal panel off the unit if you happen to have a large box fan put it in back of the unit this will cool the compressor until your new part arrives. I have had to wait 8 days for a compressor fan motor at one time and the customer I repaired the unit for had no other place to store there food. Note this fan has to be constantly running on the compressor until you are able to replace the compressor fan motor. If you have any further questions message me back Thanks
Rick
p.s make sure you have your model number when you order your part I tryed looking that model number up but it did not come up on the look up site if you need me to locate the part number that you would use to order the compressor fan motor message me back the make and exact model number of your unit Thanks again
Sep 08, 2011 | GE Refrigerators
Frigidaire Side by Side Model: PHS68EJSB0 The temperature is warm on both the freezer and fridge. They are at about 25F and 60F. I have cleaned the condenser coils and they are wet now. Initially, the...
If you have the door alarm continuously beeping you will need to try and hard reset the unit. Turn the circuit breaker for 4-5 minutes and retry the unit. But if still the 5 beeps are coming on, then its problem with control panel board.Its not detecting door closed.------- The control board needs to be inspected.---------- If the doors are not getting closed, that means some cold air is getting out and thts why temp is not getting set.This is one possibility of temperature problem.-------- But if both doors are closed tight and no issue of air getting lost out, then other possibility for this problem is weak compressor.-----------
The compressor just keeps on running.The problem is weak compressor.The refrigerant in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Aug 21, 2011 | Frigidaire Professional Series PHS68EJSB...
Compressor motors are constantly grounding each time the compressors are replaced. A new run capacitor is installed with compressor. A thorough cleanup and evacuation is performed with each compressor...
dear sir
please make sure your electrical connection to the compressor is correct and tighten. electricity supply is straight and not fluctuate i mean constant supply for unit and then change new run capacitor and make sure ground wire must connect to the air conditioner,s body and check copper filter and any other copper pipe is not block .
i think it cab be an electrical problem so check all electrical device and then re-install new compressor.
thank you
hope answer the question
please vote!
Oct 02, 2010 | LG LS180HE Split System Air Conditioner
Frigidaire Air conditioner: fas296n2a2 Compressor
Do you have an amp meter? and volt meter. Are you sure that the compressor is getting power? The click may simply be a relay closing but no power. Check both sided of the relay. You will need to trace the power and make sure that the compressor is getting power. Then check the amps to see how much power it's pulling.
Jun 15, 2010 | Heating & Cooling
Koolspace NUVO wine cooler recharge
do you have a recovery machine and gauges you need to tap both sides to check the high to and it needs to be vaccumed down to remove moisture ,find and fix the leak. leaks arnt verry common un less someone broke a line somehow. if the compressor is running it is more likley it has a restriction or bad valve in compressor, hooking to high and low sides will determine which if is less than 5 years old it could be under warrant still most sealed systems have a longer warranty than the rest of it is the evaperator getting cold at all.
Dec 31, 2009 | Vintage Keeper Koolspace Wine Cellar
Kenmore SxS 596.52673200 stopped cooling
You have a refrigerant leak. Your coil in the freezer should be frosted. You're looking at 600 dollars minumum for repair.
Sep 12, 2009 | Frigidaire FRS23H7CS Side by Side...
New Fridge beeping but no cooling
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Compressor runs constantly, fridge cools, but not as cold as new
If unit is running constantly, and not nearly as cold as it used to be, most likely a freon leak. Possibly a partially frozen over evap too. If evap is mostly clear except for about 5% of it, most probably a freon leak. Changing controls will probably not fix anything. Need to look into this a little deeper.
Good Luck and hope this gets it done for you.
May 10, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Side by side (KSRB25FHSS05) loosing cool in freezer
your compresor is hot but is it running at all or is it just humming trying to start and the just clicks off if it is just your overload that is tripp you need to replaced it that the box connected to the compressor on the left side that is why not is cooling if is running then is cheaper to buy a new one since the 5 year warranty on the compressor has expired
Nov 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
2 year old heat pump. had constant problems with both units. Have had 3 different HVAC groups out of time to evaulate problem. Replaced compressor on small unit this past summer and thermostats on both...
Look for signs of oil and you will have found the leak. Compressors depend on the cool gas returning to help cool the inner motor. At 12 pounds to recharge and leak detectors that measure less than .5 Oz per year leak rate does not figure that the leak can't be found.
10% of the oil from the compressor circulates with the refrigerant. The gas leaking will dissipate but the oil at the leak point will still be evident.
May 01, 2008 | Heating & Cooling
Maytag SkyBox MBV1976A Beverage Dispenser Logo
327 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
