Question about Pentair 250k Minimax Ch Ng Mv Heater
I have a minimax 250 i can light the pilot but the main burner will not light. i jump the th to th/pp and the pilot goes out.
  • 139 Answers
Are you sure your jumping th and th/pp? the labeling on valve is a little deceptive.should use 1st and 3rd terminal on gas valve. if your using correct terminals try same thing with thermostat wires disconnected from gas valve. this will isolate valve from all controls and safties.if it fires valve is good and need to look in thermostat loop for problems. hope this helps
Posted on Jul 21, 2009
PILOT LIGHT COMES ON BUT WHEN YOU TURN THE KNOB TO ON IT DOES NOT LIGHT UP THE CIRCLE PLATE IN THE HEATER. IT JUMPS AND THE FIRE COMES OUT THEN IT GOES OUT.
I'm not sure what unit you are troubleshooting but if the main burner is igniting and that main burner flame is blowing out the pilot flame, it's possible the pilot flame orifice needs to be cleaned. The orifice can get stopped up and produce a weak pilot. And I've seen a pilot lite, but be blown out by the combustion of the main burner igniting. Now you stated IT JUMPS. If you mean the pilot flame jumps, as if it gets large then weak and goes out, then the gas valve is giving you trouble and may need to be replaced.
Mar 09, 2017 | Heating & Cooling
My Hayward h250 Millivolt heater won't stay on. If I jump the "TH" connections I can get the main burners to come on, once I remove the jumper, the main flame goes out. I replaced the pilot assembly and...
you prolly have an electrical short somewhere. follow the circuit and if any safety is getting around 200-250 dc millivolts then theres the problem. otherwise you have an open safety switch, or tsta controls
Aug 07, 2013 | Hayward H Series Millivolt 250,000 Btu...
Pentair 250 pool heater
check gas pressure and when it goes out check voltage from transformer
May 28, 2013 | Pentair 250k Minimax Ch Ng Mv Heater
Raypak problem, Pilot is lit, can jump TH to TH to lite, goes out when jumper is removed.
check how many millivolts the pilot is generating. if pilot stay lit and burners wont fire u have a problem with one of the safties, lose wire connection, tstat control
May 28, 2013 | Raypak Pool & Spa
MiniMax 250 main burner will not light
I have the same issue, Any luck with which part may need replacing?
Aug 03, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
Pilot is lit, but burner will not come on. I jumped TH/PP to TH then burner comes on. Pilot generator = 350mV.
More than likely the tempature control is defective, since you effectively bypassed that connection. I found a manual for your unit which shows different types of ignition. I'm not even sure if the millivolt system is covered in this manual. Here's the sight
http://shop.solardirect.com/pdf/pool-heaters/gas-pool-heaters/jandy-lite2manual.pdf
Jul 12, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Main burner not lighting
Could be bad coupler or pilot valve is not staying up due to bad spring. If the light does stay lit at all, then the problem is with the fuel.
You can get the entire pilot assembly for $70 at poolcenter.com
Jul 05, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
Pentair 250 CH LP will not ignite. Pilot works
to test the presure sensor jump the wires that plug in to the sensor if it turns on the presure sensor is bad and the the thermostat do you mean thermo sensor the one that checks the water tep follow the wires to were they plug in turn power off get your finger wet and put it were it plugs in on the 2 prong and turn it on the heater will light up if the sensor is bad
May 11, 2009 | Pentair 250k Minimax Ch Lp Mv Heater
Pentair 250k Minimax Ch Ng Mv Heater Logo
560 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
