Question about Panasonic DMC-FX37 Digital Camera
When turning off the camera, the lens does not retract. I also get an error message "SYSTEM ERROR (ZOOM)" and another one "PLEASE TURN THE CAMERA OFF AND THEN ON". Once the camera is turned on, I can hear the lens mechanism working, but obviously failing.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
System error focus
you hve probably damaged the lens unit. impact while the unit was extended? the auto power off will retract the lens thus damaging the little plastic gears in the lens unit. you may need to replace the lens unit
Dec 18, 2013 | Panasonic Lumix Dmc-fh1 12 1 Mp Digital...
Digital zoom error on an A600, lenz will not retract either
Have you tried spraying a can of compressed air into the lens assembly? All it takes is small piece of debris like a grain of sand to jam up the assembly.
Hope this helps
Jul 07, 2008 | Fuji FinePix A600 Digital Camera
System Error (Focus)
The systems control board has detected a problem with the auto focus lens, the focus is controlled by a tiny motor that has jammed or there is a mechanical issue with the camera lens. It will require a technician that is highly skilled to deal with the situation, but the repair cost would probably not be justified.
Jan 12, 2011 | Panasonic DMC-FX37 Digital Camera
How can I rectify the "zoom error" message on screen - also the lens will not retract either
Hello
Unfortunately a "zoom error" message is not something that you will be able to fix. This error indicates a system failure (apparently your lens is damaged, since it will not retract) and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Oct 12, 2010 | Fuji FinePix J10 Digital Camera
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
System error: zoom message with Panasonic Lumix FS15 camera
I had the same problem, i switched the camera on in capture mode and zoomed in and applied a little pressure to the lens which made a slight click but retracted and has worked fine since. I may of just been lucky but the camera is fully functional again, could be worth a try.
Jul 20, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Canon ixus 75 digital camera reset?
Hi
What you are seeing is just an error message, starting your camera again won't do anything unfortunately.
You need to replace the lens, we have your lens repair available on our site for about $75! If we can help please let us know.
Thomas
Owner- Darntoothysam com
Apr 07, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Zoom will not retract
Dear Grammie,
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
Sincerely,
HeavyDLB
May 22, 2008 | Canon PowerShot A540 Digital Camera
Lens stays zoomed out, no error messages
i'm sure it's broken(the camera) take it to a service and get it fixed....
Mar 26, 2008 | Canon PowerShot A460 Digital Camera
Panasonic DMC-FX37 Digital Camera Logo
194 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
