Question about Nintendo DS Lite Console
Ds lite wont come on
Dslite when i switch it on the orange lite will only stay on for about 1 second.could this be a fuse or the main board
  • 51 Answers
Try charging it.
Posted on Jul 19, 2009
DS charging..light stays orange...
It could mean that the Motherboard (Main Circuit) could be damaged or could be a fuse problem as you may have said. Although it actually might be the battery, there's one way to find out, if your friend has a DS Lite, ask them if you could borrow your battery for 2 seconds and put their battery in yours to see if it is the battery, if the same thing happens, its the Motherboard (Main Circuit)
Jul 06, 2013 | Nintendo DS Lite Console
When charging DS lite the light stays orange
The issue is not with the fuses or with the battery. That end is working properly if the light stays a constant orange. The issue is with the other end, how the system powers on. Check the power slider (on mother board) or the L2 inductor (located below the slider). Chances are the tab on the slider has broken off or the L2 slider broke off from the motherboard.
My Ds will not switch on. It worked this morning, it wont charge and it wont switch on either....It is a DS lite console, only 4 months old.
Your DSlite could have come into contact with liquid, OR the battery is bad.
Both are very possible and very likely.
I would try another battery before sending it out for repair. Aside from a blown fuse inside your Nintendo DS Lite, these are the only causes of no power.
Please try a battery first.
If that does not work, you will have to send this in for repair.
Goodluck and I hope I helped.
Apr 11, 2010 | Nintendo DS Lite Console
What should i do if my ds lite console doesn't turn on even after i changed the battery?
HELLO!
There seems to be a blown fuse. Search on the internet for "How to Replace DsLite Blown Fuse"
OR
There could be liquid damage to your board.
Dec 28, 2009 | Nintendo DS Lite Console
Will not turn on
Since you've already replaced the battery it could be a fuse issue.
The DSLite has 2 fuses and either one could be the cause of the problem.
To fix this problem it has to be opened and repaired.
Apr 13, 2009 | Nintendo DS Lite Console
My DS will not switch on with or without the charger connected. When i plug into the charger the orange light flashes for 1/2 a second and goes out again, but no other reaction. My ds won't switch on but...
try to charge it with another battery,if that does not solve the problem then there is a blown fuse inside the board.its besibe the battery terminal to the right.but first you have to open the unit using a triwing screwdriver and a small precision phillips screwdriver.
Dec 18, 2008 | Nintendo DS Lite Console
Nintendo ds wont charge
cheekiemunke,
First of all, your DS Lite is charging both ways.....with power on and without power on.
You have for almost 99% sure a blown fuse F2 on the systemboard.
If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash.
So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
Regards
John
Nov 27, 2008 | Nintendo DS Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
NINTENDO DS LITE WON'T CHARGE OR POWER ON
Hey everyone, not sure if this will work for everyone, but its worth a shot.  my problem was identical to all the others here, a flash of orange and then nothing.
i thought perhaps those little metal contacts on the battery and the ds had build up a little corrosion, interrupting the charge.  so, i took some rubbing alcohol and q-tips and gently scrubbed them clean, both on the battery AND the ds side.
After this, my ds has worked flawlessly.  Hope it's the same for you!
Feb 06, 2008 | Nintendo DS Lite Console
DS Lite does not power up
If the console has overcharged or has been used for long periods of time or could just be fluke, chances are the fuses are blown on the main motherboard try this link, this guy fixed my ds and i had the exact same problems as you guys have
Sep 10, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
60 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
