Question about OKI C5300n Led Printer
OKI C5300
Printer tells me I have a toner cart. sensor error, but all cart. are new and installed.
  • 97 Answers
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
Posted on Dec 07, 2008
SOURCE: oki c3400 toner sensor error
I found the solution here.
A plastic thing was closing the sensor window. Open the window and you will solve the problem.
Posted on Jan 26, 2009
SOURCE: OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Posted on Apr 16, 2009
SOURCE: Have an OKI Printing Solution
Found this at
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
  • 13 Answers
SOURCE: I have a new OKI B410d printer which is givng
It is more than likely that you have an incompatible toner fitted to the drum unit. Either a generic cartridge or b430 or b440 cartridge which is not compatible with b410's. Beyond that it may be a faulty drum unit. Hope this helps.
Posted on Sep 14, 2009
  • 22 Answers
SOURCE: Machine flashing K Toner Sensor Error - how do I
See if this works - switch off at mains, pull black toner part way out, push back in, switch on again.
Posted on Feb 21, 2010
0 characters
1 Points
Message on window: check toner cartridge 542: C toner sensor error
try a different toner first .... doesn't have to be a full one ... just a different toner box. had the same on a machine and it was only a bad toner cartridge. so the easiest thing to do is swap drum units with toner installed ...
if it turns out to be the cartridge you can have a look at the right side ... there is a hole in it and a white plunger moving there and gives the machine the current toner amount in the cart.
Oct 24, 2009 | OKI C5500n Printer
How to do borderless printing with an oki c5300
You cannot do borderless printing with a toner/fuser based unit.
The printer needs a paper grip area and cannot print to the edge due to the fuser.
Sep 30, 2009 | OKI C5300n Led Printer
LED Head Missing, Color:Magenta
Take out the magenta cartridge to the right upper indside wall of the printer you should be able to see a small rectangular window, give it a blow of wipe with a cloth, do the same to the corresponding part of the m toner, put the drum and toner back, shut the lid and everything should be ok. If not contact oki for a replacement drum/cart.
Mar 23, 2009 | Printers & Copiers
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
Fatal Error 162
I am pretty sure this is the result for your 162 code:
Toner Sensor Error, Color:Cyan
When cyan toner sensor error has occurred
Try reseating your toner carts.
May 14, 2008 | OKI C5150n Led Printer
Oki 9800 fatal error 230
No reset need to fix fault then clears...
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
Oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Problems with Oki Printer and Toner Sensing
Yup Dodgy refill cart without require chip to identify itself to the printer or cart not suited to b4200/4250 , get a real oki toner from your country that suits exact model.
here is code for required product
Oct 31, 2007 | OKI B4250n Laser Printer
Oki C5300 toner "leaking" on to surface
1 - take out all consumables
2 - use canned air to clean interior (do it outdoors)
3 - spray toner cartridges to remove stray toner (keep them connected to the drums, do not separate)
4 - make sure toner carts are properly installed and locked down
Oct 25, 2007 | OKI C5300n Led Printer
OKI C5300n Led Printer Logo
284 people viewed this question
Top OKI Printers & Copiers Experts
Level 1 Expert
Dominion Computer...
Are you an OKI Printer and Copier Expert? Answer questions, earn points and help others
