thats a lazer problem in the cd usually a cd cleaning disk will sort that problem if not a its the lazer head thats distorted best this to do it put a conversion tape to ipod or iphone and play your tunes off those devices via your tape, there only cheap to buy.
Try this as the stereo may need to be reset- If you have jumped or replaced the battery at anytime this will happen. You have to get the serial number off the radio by removing it or partially taking it out to see the numbers on it try not to remove any cords. With the stereo out (to make sure you get the right number off of it) call an Acura dealership with the number and they will give you the another number to enter into the stereo and directions on how to punch the numbers in. Make sure while you have the stereo out you write the serial number down and keep it in a safe place also the number that the Acura dealership gives you because if you sell the car or if it happens again its easily accessible. Good Luck!
this happened to my 04 tl. it would stay on for the radio but once i hit the cd it would completely shut down until i turn the car off. i had to take it back to the dealership and they had to have it replaced. if you got the car not too long ago you should take it back since they shouldnt be selling you a car with parts that will fail so soon or if you have a warranty then it should be all good.
for your 2003 TL 1. first remove the CD player (this is the hard part). 2. with the CD player removed, unscrew the top cover (4 or 5 screws) on the CD player. 3. with the top cover removed you can see the stuck CD. 4. all you have to do now is just push the CD out and reinstall
Humm, does it give you an error also... like "E01" for example? well actually it doesn't matter because if the radio works fine with volume, it's going to be in the audio unit. Acura's with this particular radio unit has many, many CD player problems. you can have it repaired at a great expense or just replace it with a nice aftermarket radio instead. It's up to you...but it's going to be in the audio unit its self.
instead of fill it gas i axcedently fill it with diesel please let me know what to do and by the way i did not use it cause it start shirffing when oi press on the gas
