It means that you must have the engine control module (known as the PCM) scanned for fault codes, this light can be turned on by literally hundreds of different faults.
part supplied says a spanner
undo the wire connector
undo the sensor
fit the new sensor
fit wore connector
if coolant is lost refill cooling system to correct level
Check the thermostat. It monitors the temperature of the coolant and turns the fan on to cool the engine when it detects the temperature is too high. When it goes faulty it can cause this issue of the fan being on all the time. (Better that it fails on than fails off and overheats the engine).
go to the under the dashboard or to side the drive door they have small cover and you will see the name for each fuse. or go www.automecanico.com or www.youfixcars.com and try.
