Question about Canon PowerShot SX100 IS Digital Camera
I have the canon sx100 is, it dropped and now the shutter eye won't open
    Novelist:
  • 164 Answers
If only the shutter eye is not opening but the lens is extending properly, then you will need to remove the fron shutter frame and review it.
It may be that one (or both) springs that open the lens protector are loose, or the plastic tab that allows to open/close the lens protector is broken.
If the lens does not extend when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solutio is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Posted on Jul 22, 2009
I have a Canon PowerShot SX100 IS and would like to know how to set the self timer to take pictures.
Press the self-timer button (marked with a one-handed clock). Use up/down to select an option. Start the self-timer by pressing the shutter release button as normal.
Aug 28, 2011 | Canon PowerShot SX100 IS Digital Camera
I dropped my Canon PowerShot SX100 Camera. It takes photos just fine, but I can no longer download to a computer. When I turn on the camera for downloading, a "communication error" message...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 19, 2010 | Canon PowerShot SX100 IS Digital Camera
The screen on My Canon Power Shot SX 120 IS camera will not show any images when I turn it on. It simply shows black, if I take a picture, the picture will record on the memory card but it is also just a...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 18, 2010 | Canon PowerShot SX100 IS Digital Camera
How to correct red eye
One of the flash settings on your camera is for red-eye. If the pic you took already has red-eye, you can remove it with a photo-editing program.
Oct 31, 2010 | Canon PowerShot SX100 IS Digital Camera
Canon SX100 camera The lens shutter keeps sticking and the lens gets stuck
Sounds like your lens is not retracting due to the fact that the internal alignment is off. You might have bumped the camera with an open lens and not the sliders are out of alignment. there are very fragile pieces in there that keep the lens aligned, when they are off, the lens keeps acting up. this company will give you an online quote immediately to fix it http://www.teleplancamerarepair.com/Canon_Powershot_SX100_IS
repair includes camera cleaning
Jul 16, 2010 | Canon PowerShot SX100 IS Digital Camera
My canon powershot SX100 IS has image stabilizer, but apparently I'm not using it properly. All my pics, even stand still pics, turn out blurred. What am I doing wrong? My sons graduation pics were ruined,...
Image stabilizer (IS) will help you stabilize your shaky hand when photographing static object in dim light environment. When photographing moving things such as humans, camera IS will not and cannot not freeze them unless you use high shutter speed. If your camera allows high ISO and manual shutter speed setting, experiment indoors with it. Just remember, high shutter speed freezes motion and IS can only steady your shaky hand for so long. Tripod can only steady your camera not the subject if the subject is a human being.
Aug 18, 2009 | Canon PowerShot SX100 IS Digital Camera
The camera won't turn on.
Did you try taking out the batteries?
Nov 27, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon showing black screen
needs to go in to a camera shop for repair, either the shutter is broken in the lens or the CCD is bad...could be more than that but, It would have to get disassembled to determine that. I work on Olympus cameras and have found that sometines it's easier to let someone with a box of spare parts fix it...
Jul 26, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot SX100 IS Digital Camera Logo
292 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
