Westinghouse LTV-27W2 27 in. HDTV-Ready LCD Television
Problem for Westinghouse LTV-27W2 27 in. HDTV-Ready LCD Television
The color in peoples faces has turned blue
By roiemiriam on Jul 18, 2009
Solution #1
posted on Jul 18, 2009
Somewhat Helpful)
stonephoenix
Rank: Guru
Rating: 91%, 602 votes
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting unless someone has recently bothered the connections or your cable is on the fritz. Otherwise, there is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Was this helpful?
Yes
No
Popular Solutions for Westinghouse LTV-27W2 27 in.
Questions and Unsolved Problems for Westinghouse LTV-27W2 27 in.
Do you recommend Westinghouse LTV-27W2 27 in. HDTV-Ready LCD Television?
Answer
Answer
ltv 27w2 can i adjust the color on the tv itself, w/o the original remote?
Answer
I have this running thru a cable box and haven't changed anything for a lllonnnggg time. It is... (More)
Answer
my westinghouse LCD model LTV-27w2-b keeps cycling through on and off. Will be on for a few... (More)
Answer
I have a 40" Sony Bravia KDL-40v5100 that is approx. 1 month old and is hooked up via HDMI to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Westinghouse LTV-27W2 27 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
