Question about Brother HL-2070N Laser Printer
Paper light constantly flashes
The Paper light constantly flashes red. Have taken the printer to bits and cleaned all the parts, have even replaced toner and drum. anc changed the type of paper being used. Still the peper light flashes red.
  • 5 more comments
  • grant121 Nov 29, 2007
    I was able to print the test page per the advice. I reset the paper type and checked the other settings.
    The printer will print e-mail messages sometimes and I was able to print from Notepad, but the paper light flashes red when printing from Word 2003.
  • AnnaLouise Jan 07, 2008
    Ditto re red light suddenly flashing, after using it just fine last night (and for the past year!) ... and with no paper jams (I've checked thoroughly).
    Damn, just as I'm starting a big work project, too.
    I'm following Soulvisitor's advice (thank you, Soulvisitor!!!), and so far the test print has worked fine so there's simply some glitch or overload somewhere. Will continue with S's suggestions ....
    Fixed it! Turned out to be a wonky setting in Word. Whew. (Again, thanks for the help here that pointed me in the right direction.) -- A.L.
  • kimk117 Jun 22, 2008
    Paper light flashes "Paper" in red even though paper is in the paper tray. Why is it doing this and how do we fix it?
  • Anonymous Dec 02, 2008
    These suggestions did not work for me.... anything else that can be done short of taking it to be repaired?
  • awier Jan 02, 2009
    I have the same problem. I tried the [soulvisitor] solutions, but it is still blinking. I have opened, cleaned, and disassembled parts to be sure there are no bits of paper in jamming a sensor. It's not a bad print job (memory, complex document, paper size) as I have cycled the printer power many times, disconnected it from ethernet and USB - even left if off overnight.
    Is there a hidden reset button somewhere that I can try? All help is greatly appreciated.
  • Anonymous Apr 12, 2009
    Same problem. Same attempts to clear/reset sensors.
  • Brother Master
  • 1,113 Answers
That flashing paper light indicates a few things on these, most often it is related to paper not in tray or jammed/not picked up but I see in you case it isn't.......
Your light can also be indicating that the page size sent, it doesn't think it has so it is asking you to feed correct size paper as per document that you sent it, into the little slot at the front called the bypass...(change paper size setting in tray or document page size).
You can test if above is problem by unplugging USB turn off/on machine should come to green, press go button 5times supersuper fast, test print should print shortly.
If printing labels, card, transparencys or have setting as this paper type machine will default to manual pass (cause it needs to be feed those sort of things, straight, not from cassette.
It can also mean memory full or print overload, (pressing go button will start print of remaing data) Doc too complex
or Door open front or back
or even Clean Carona (blue slidy thing on drum)
Drum light fix below
Open cover
Press and hold down Go button for about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the Go button
Close cover
link to MANUAL
Posted on Nov 19, 2007
  • Soulvisitor
    Soulvisitor Dec 07, 2007
    Grant look at page size settings of documents you are truing to print it is set diff to printers tray size ie in word, file, page settup, paper.... also your default will be wrong once you change page/paper size on doc click set as default option too any old doc you open will still be wrong change and resave, new ones will be right now
Okay guys this is gonna sound stupid, but i called my IT guy. he came up, DC'ed the unit and placed it on my desk. he then reconnected it and it worked fine. apparently, after much trial and error, he figured out that moving it from it's stand and placing on a flat surface fixes it every time. however, this may just be isolated to my printer. but it worked so i thought i'd share.
Posted on Oct 23, 2009
I have had this problem intermittently for months then I read a post that said it was a dodgy setting in Word but gave no details so I did some investigating and found that the paper source was set to "Manual". Go to File > Page Setup > Paper > Paper Source and change to "Default Tray (Auto Select)". Now works fine.
Posted on May 07, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Had a paper jam and my daughter pulled the paper through the front now it wont work and the red light keeps flashing, Is my printer ruined now??
what you need to do is restart the printer and if you get the same problem try cleaning the front of dirt and dust ( maybe bits and pieces of paper still blocking the sensor) that's why the red light keeps flashing.
Jun 08, 2011 | HP Office Equipment & Supplies
PAPER gets stuck in the printer and red lights comes on. Paper is getting constantly stuck in printer and so I can't use printer.
Try cleaning the roller on the front part of tray. It may be dusty. When it is dusty paper can slip and cause paperjams.
Mar 27, 2010 | Brother HL-2040 Laser Printer
I know by human nature that the situation was taken care of but if not
.Press abort or cancel printjob
Worst case turn off the printer and with a constant tug remove the paper MAKE SURE POWER OFF THE PRINTER...
Aug 11, 2009 | Epson Stylus Photo R1800 InkJet Printer
Brother HL-1435 won't print, thinks it's out of paper
Please see the following support articles that concern paper feed and jam problems on your machine: here, here, here,
If the Paper Source is set to manual you will receive this error. (See use guide pg.1-10) (here)
REmove the paper tray completely, open the rear access door and make sure there are no bits of paper anywhere. Then reinsert and restart the printer.... If all else fails, you could try a factory reset as described here.
Jul 26, 2009 | Office Equipment & Supplies
HP Business Inkjet 1200 Lights flashing
Check the paper sensor has not come loose. Lift the lid, it is on the right hand side of the rollers with the red and blue wire. Press down lightly to make sure is hasn't come loose.
If not, reset the printer:
While the printer is on, press and hold the configuratuion button and press resume (paper feed) button 3 times.
Wait 20 second and press the power button.
Disconnect the power and wait 20 seconds.
Connect the power and switch the printer on.
Feb 24, 2009 | HP Inkjet 1200dn Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Kyocera mita ecosys fs-1010 - Flashing light red light and clicking sounds
clean or replace the rollers that feed paper into the copier... use rubbing alcohol or isopryl alcohol to clean them...
Mar 08, 2008 | Lexmark Z640 InkJet Printer
Paper feed problem
please check if the rubber roller that pulls the paper inside the machine check if it is clean because after long use this roller becomes so smooth ddue to dust and doesnt take in the paper , first clean it ,wipe with wet towel  try again
Oct 27, 2007 | Xerox 5305 Copier
Brother HL-2070N Laser Printer Logo
845 people viewed this question
James Cagle
James Cagle
Jim Keysor
