Question about Dell Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply
Push button small light in middle comes on fan on power pack turns 1/4 turn and that is it
I have this problem with my E Machines W 3104 and i unplugged it and still i could make the fans turn on like you said for maybe a quarter turn, plus the lights would basically flash once every time i pressed the power button. after the little death beep noise from inside when it loses power completely i plug it in again and it will turn on just fine . the first time it did that i thought it was because it had too much power built up in the power supply, and maybe it did but it ussually turns right back on after "draining it". try that and see if it helps at all
Posted on Nov 25, 2009
My remote lights up when you press the button but it's not controlling my fan.
Controlling a ceiling fan/light using a wall switch causes the remote control to lose its memory. You will have to start all over at the beginning. Remove batteries from the remote, push all buttons to eliminate a stuck button as a cause, then reinstall batteries but do not push any button yet. Be sure all wall switches are off. Go to the power source for the fan/light (not the wall switch) and turn it off. Wait briefly, then turn on the power at the source again. Try remote operation. If successful, use only the remote to control operation. Forget about using the wall switches.
Dec 21, 2013 | Dryers
Hp pavilion desktop won boot
test the power cord+ outlet for faulty with multimeter. However if this things are o.k You must test the power supply pack for faulty, test the 5 vdc+12vdc, etc and see if there are Faulty. and replace. Please tight cable or connector inside. Test too the small battery for CMOS for +3vdc and replace.
God bless you
Nov 06, 2013 | Computers & Internet
Malibu TDC PTST-30012 turns on in the middle of the day
1) Contact malibu lights directly.
Their site does not acknowledge TDC PTST-30012, so I cannot access a manual with best information.
Their products come with a warranty.
http://malibulights.com/customer_service/contact_us.aspx
http://malibulights.com/customer_service/owners_manuals.aspx
2) If unit can be set to override, you can buy cheap photo eye timer, and then plug power pack into cheap timer, but there is no guarantee this will work, or that power pack will burn out.
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
3) Buy ordinary power pack with dial-type timer, and then buy photo eye that fits.
http://www.intermatic.com/products/professional%20lighting/light%20expressions/accessories/ml814drp.aspx
http://store.nexternal.com/intermatic/categories.aspx?Keyword=ML814DRP&x=15&y=10
4) As electrician, I would not buy anything that costs more than $15 that comes with built-in photo eye that cannot be replaced.
Especially something as buggy as a low voltage power pack.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Feb 14, 2010 | Intermatic Malibu 300W Power Pack...
Lights come on but no fans or powerup
Please follow the steps below.
1. Please removed the battery and unplugged the power supply.
2. Held down the power button for 45 seconds.
3. After 45 seconds reinstalled the battery and the power supply and pushed the power button and if it works then you don't need to replace your motherboard.
4. Else try it couple of times or up to five times before it worked if worst comes to worst.
Thanks
Aug 26, 2009 | Acer Aspire 5050-3242 Notebook
Computer will not turn on
May sound strange, but is the power supply switch in the correct position?
If the button is pressed, makes your continuity test, and not even the fans come on, check that the switch jumper has not come loose from the motherboard, and finally, if the motherboard is plugged in and no fan comes on when you push the power button, there may be chipset damage from an electrical surge or overheating.
In this case, a new mobo is your only option.
Jan 20, 2009 | Dell Dimension 4600 PC Desktop
Ps2 slim console wont turn on!
i checked the manual (troubleshooting) 1. turn off PS2 2. unplug it then, plug it back in and turn it on(andprayitstillworks).
Jan 10, 2009 | Sony PlayStation 2 (PS2) Console
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Laptop will not power on at all.
Don't know what you have for a laptop, so will have to give you a generic process, here. Power down. Remove hard drive, remove cd reader and/or floppy drive. Remove memory cards. Replace only 1 memory card in the main slot (probably marked as slot 1). Try to power it back up and let us know what happens.
Thanks!
Ron-
Nov 02, 2007 | Computers & Internet
Dell Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply Logo
149 people viewed this question
Alun Cox
