Question about Metra Ford F 150 Truck 1996 Up
2005 ford f-150 4.6l
When air cond is on truck will die...low idle
  • 66 Answers
Sounds like you have a bad IAC. Idle Air Control Valve.
Posted on Sep 08, 2010
Can i adjust the idle air control valve on my 2005 Pontiac Grand Am
No.
  • Regulates the amount of air entering the engine during idle
  • When bad, vehicle could experience high or low idle, engine dies at idle and/or severe high idle possibly causing internal engine damage and safety issues
Sep 22, 2015 | Pontiac Cars & Trucks
My 2005 dies at low idle always starts back up but dies alot especially in the day when it is hot. I think it is the mass air flow sensor but would like other opinions.
More likely an "idle bypass" setting, or it just needs cleaning. The MAF sensor doesn't have much to sense at idle.
Jun 17, 2015 | Cars & Trucks
2005 Ford Taurus low idle
Replace the idle valve with a factory one and remove the negative battery negative cable for 5 minutes to reset the idle control system to base line settings.
Oct 17, 2012 | 2005 Ford Taurus
Air cond
sounds like a low freon charge look for leaks in the right rear corner where the lines go threw the floor to the rear unit
Jun 05, 2012 | 2005 Dodge Caravan
Air Conditioner not cooling at idle
it is low on charge due to a leak most likely, have the system pressures checked.
May 25, 2010 | 2005 Ford F 350 Super Duty
Where is air cond. orfice on a 2001 tauras i know
low side fitting is located by firewall on passenger side on low side hose, which is the big aluminum line...high side fitting is closer to radiator on smaller aluminum line
Aug 15, 2009 | 2001 Ford Taurus
A-c warm at idle cool moving down road
may have partial restriction. and while driving down the road the compressor is moving faster and forcing past the restriction. try changing the filters in the a/c line.
Aug 03, 2009 | 2005 Ford Five Hundred
1996 f250 gasoline v8 - died and will not restart
If the defroster was on then the air cond compressor was running.and you may want to add that to your list of things to check .the a/c is used in winter on defrost to help remove moisture from the air and the windshield
Dec 17, 2008 | 1996 Ford F250 Crew Cab
2002 ford explorer
I am guessing here w/o much info, 1 of maybe 4 things, idle speed contoller motor, low fuel pressure, dirty air filter, or lastly, carbon buildup on the throttle body throat. When cold idle the carbon blocks off the little needed air and the engines will run rough or just die.
Aug 26, 2008 | 2002 Ford Explorer
Metra Ford F 150 Truck 1996 Up Logo
106 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
